h22 ground problems
Old Jul 11, 2013 | 06:57 PM
Big Rhag's Avatar
Default h22 ground problems
ok this is whats going on the car starts and runs fine and out of nowhere it would stall and each time that happens the right signal light stays on and so does the radiator fan even when the key is out i checked the wiring diagram for the fan and singal light and the ground isnt the same so idk what to look for now
any help would be nice
Old Jul 12, 2013 | 03:08 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: h22 ground problems
Clearly it's not a ground issue. Check for shorted/crossed wires in every harness. That's the only way thatcould hhappen
Old Jul 12, 2013 | 05:10 AM
Big Rhag's Avatar
thanks for replying do i check the wires from the fan and signal or it could be any wire?
Old Jul 12, 2013 | 05:19 AM
wantboost's Avatar
Who is Mr Robot?
Could be any wire. You've got a massive amount of work in front of you. I suggest a good multimeter and continuity tester/light. Those two tools will save you a bunch of time and heartaches
Or find a local shop with a good wiring guy and let the pros do it
Old Jul 12, 2013 | 07:19 PM
Big Rhag's Avatar
found out the problem the two wires from the coolant sensor was touching each other thanks for your help man
ramboPandA
Jul 28, 2015 07:41 PM
FOUR-G
Mar 26, 2010 09:37 AM
wanabebuff
Nov 2, 2009 01:49 PM
Hung_Lo
Jun 17, 2007 06:55 PM
mike5809
Honda Motorcycles
Aug 21, 2006 12:03 PM
