h22 build
Old Apr 15, 2007 | 01:35 AM
h22silvia's Avatar
Default h22 build
ok i was wondering w/c valvetrain to go with. bottom end i knw i have to sleeve it but from wat i heard theres another route so u dont have to sleeve it.if i went with the mahle pistons gold series do u guys think i would able to boost really high and produce 500 whp.is egle rods would able to hold 500 whp thanks
Old Apr 17, 2007 | 08:52 AM
h22silvia's Avatar
morning bump
Old Apr 17, 2007 | 09:01 AM
PrecisionH23a's Avatar
Default Re: h22 build (h22silvia)
I have had several set-ups break 500whp on the eagle rods. Typically I use them for around 450whp and after that I prefer to use a better rod.
As far as the mahle's go, search. You are much better off running a traditional forged piston and having your block sleeved. FRM lined cylinders are tricky to work with and not very many people will hone them. For valve-train components, I would go with supertech
Old Apr 17, 2007 | 12:02 PM
RudeLude's Avatar
Default Re: h22 build (PrecisionH23a)
mahle pistons, eagle rods setup here...only running 8psi at the moment, i will be upping the boost this weekend...i'll post results when i'm done...
Old Apr 18, 2007 | 09:12 AM
h22silvia's Avatar
before i bent the valve i was pushing 261whp and 221tq on 7 psi on stock motor jdm h22a w/ a f22b tranny.
will supertech valvetrain work with crower turbo cams
ekcoupeh22
Feb 22, 2010 07:14 AM
SiR-T
May 17, 2007 05:13 PM
Jdmprelude94
Feb 11, 2007 08:14 AM
projectaccord
Jan 27, 2007 05:46 AM
fracas
Dec 28, 2005 03:08 PM
