GT35R ls/vtec progress thread
Old Jan 12, 2011 | 01:47 PM
  #26
rwlsvtec_03's Avatar
Post new stuff
fresh buy's
B&R fittings catch can drain back kit
Old Jan 15, 2011 | 04:02 PM
  #27
Default Re: GT35R ls/vtec progress thread
Seats out, carpet in, one seat and harness in.
Old Jan 15, 2011 | 10:17 PM
  #28
g0tgot's Avatar
and the limited edition black hks ssqv FTW
Old Jan 16, 2011 | 02:08 AM
  #29
damn straight. I wanted to go with black everything but every part is an upgrade for black. That BOV is the only thing that didn't cost extra for black.
Old Jan 23, 2011 | 07:33 AM
  #30
NR>G catch can mount mated with B&R fittings mounts/hardware. Can, drain line, block plug and drain fitting should be installed today. garage is currently 6 degrees BTW. Bungs should be welded to valve cover by the end of the week.
Old Jan 23, 2011 | 02:08 PM
  #31
Got can mounted in place of old but I think it's too low to drain properly. Need massive allen wrench to put in drain fitting so no lines connected yet but evap can is now off and block plug is in place.
Old Jan 26, 2011 | 05:56 PM
  #32
Valve cover is sent down to iron works to get bungs welded. Should have back by Friday.
Old Jan 29, 2011 | 06:52 AM
  #33
Bungs are welded. Valve cover is re-wrinkle blacked. Should be back on this afternoon along with all plumbing and raising height of catch can.
Old Jan 30, 2011 | 04:34 AM
  #34
Icon7 Progress (B&R)
Got done last night. Tell me what you think**
photo quality is pretty low, not much light at night.
(catch can drain back kit from B&R Fittings here on H-T)
Old Jan 30, 2011 | 09:36 AM
  #35
cutter's Avatar
good looking build
Old Jan 30, 2011 | 11:31 AM
  #36
Originally Posted by cutter
good looking build
thanks. almost done..
Old Feb 5, 2011 | 05:25 AM
  #37
Guess I am taking all the MSD ignition off and swapping with my 2000 Si for oem.
Also probably going to have to swap out HKS blow off valve for a Tial piece considering HKS model tends to leak passed 17psi. Considering getting meth injection added.
Other than that just brake master cylinder and seat brackets welded then headed up to Innovative Tuning in Buffalo, NY. Getting it trailered there for valve adjustment, smoke test, break in and everything else. 450+ WHP!
Old Feb 5, 2011 | 06:17 AM
  #38
chuwi's Avatar
amaizing work..!!!
keep the good work!!
Old Feb 5, 2011 | 09:11 AM
  #39
anavrin's Avatar
hmmm i thought for higher HP that u need a bigger catch can??
Old Feb 6, 2011 | 09:58 AM
  #40
BoostedEKFerio's Avatar
Niccee
Old Feb 6, 2011 | 02:17 PM
  #41
Icon7 Re: GT35R ls/vtec progress thread
No.
Originally Posted by BoostedEKFerio
Niccee
Thank you.
MSD Ignition is swapped with my 2000 Si oem stuff.
Old Feb 28, 2011 | 02:12 PM
  #42
O ring is out of the motor and some stainless braided fuel line and hardline adapter along with a jegs 9" fuel filter and aem fuel rail. Ordering a Cooling Mist water/methanol injection kit soon to try and reach the 500hp mark.
Old Feb 28, 2011 | 02:20 PM
  #43
area522010's Avatar
oooooooooooh heeeeeeeeeeeell naaaah(twirling my neck and snapping my finger) you got a obx manifold and you prob brought it from ebay, oh i cant wait til that **** crack in 2 weeks lol.
nice build bro def looks good. nice to see guys paying attention to there body also and not just there motor. def keep us updated
Old Feb 28, 2011 | 10:21 PM
  #44
eg:R's Avatar
Why take out the o-ring?
Old May 1, 2011 | 05:40 AM
  #45
Icon7 It's been a while! progress
Dropped off @ Innovative Tuning!
Installing Cooling Mist CMGS FS methanol kit w/solenoid & 1gal. tank
along with smoke testing, compression testing, valve adjustment, swapping out map sensor and checking everything and tune. Hoping for 500whp on the Mustang Dyno.
bay 4/24
Built a glove box gauge cluster. Needed for CMGS controller. Oil pressure gauge is just sitting, getting an aem in time. From drivers seat you can see both perfect. I left space on right to get a turbo timer placed in.
Old May 3, 2011 | 07:38 AM
  #46
GSR.BoostedB18C's Avatar
Niec build!! I love the clean engine bay!!
Old May 7, 2011 | 11:59 AM
  #47
Appreciate it. Hope to have back by Friday!!
Engine bay has a few little screw holes where the old catch can mounted and a couple chips here and there.
Boner_Ben
Jan 28, 2007 06:25 PM
jdmcommute
May 27, 2006 06:47 AM
SoOHiGH
May 29, 2005 10:15 PM
96IntegraSE
Dec 4, 2002 09:12 PM
