bw S366 outlet vband size?
I have a 83 ar t4 outlet s366. I was wondering what size vband this is. I measured the outlet diamter at 3.25 and the size of the flange at 4.25. Do i use a standard 3.25 flange? I have read somwhere that you can use a standerd 3.5 vband flange and clamp. I dont know what to order.
Moderator
Re: bw S366 outlet vband size?
You can't just get the 3.25" v-band flange because it is set at a different angle than Garrett or Precision. The S366 w/ the T4 outlet is a John Deere part originally. You need to contact Bullseye Power, as they have that v-band clamp & Flange available for that size.
http://www.bullseyepower.com/contactus.asp
Talk to Dave H. or Bill Devine
How the hell did you find this information? Thank you!
I also found them here:
http://racepartsolutions.com/proddet...FLANGE&cat=102
What are everyone's power goals?
I have a 1.9L miata. Only 4 other people have run turbos this large on Miatas before so I'm not sure how much power to expect. I'm guessing 25psi will get me to 580hp, 30psi 630hp? Dunno.
