gt30r b16 wastegate size
i just picked up a gt30r and am using a ramhorn man and wanted to know what would be the best size wastegate to get.
setup is
stock b16
1000cc injectors
chrome or uberdata (havent decided yet) would like some facts why people say chrome is better
3 inch dp with e cutout
decent intercooler with 2.5 inch piping in and out..
hks ssqv bov
i was thinking about a 38mm tial but this is my first turbo setup i just sold a fully built b20vtec. and im just getting started with this stuff
setup is
stock b16
1000cc injectors
hks ssqv bov
BANNED
Re: gt30r b16 wastegate size (Drum and Bass Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drum and Bass Racing »</TD></TR><TR><TD CLASS="quote">i just picked up a gt30r and am using a ramhorn man and wanted to know what would be the best size wastegate to get. </TD></TR></TABLE>
what wastegate flange is welded on the manifold?..you only could used what wastege its flange for...unless you're gonna cut it off and weld a new flange for it...you can use anything from a 35mm-46mm from tial or other company...but whats your hp goals?...
im gonna push the b16 harder than normal and go to church and get a good tune. but i drive my car like 10 miles a day on average so barely get the surface rust off my rotors
ill be driving the b16 forlike 3-4 months till i throw in a built block, so i will prob run a pretty high (safe) boost level. hoping to knock on the door of 300hp
Choose a high quality and well designed manifold first, then buy the wastegate the manifold is fitted for.
big turbo + low boost = large wastegate.. more exhaust gases to vent off.. (open more)
big turbo + high boost = smaller wastegate.. less exhaust gases to vent off.. (open less)
small turbo you can run a small wastegate 35-38 etc..
Dont go double your spring pressure, or you can creep easier...
It gets tricky when you get into high/low boost setups with big turbos to avoid creep.
Goodluck.
Goodluck.
Re: gt30r b16 wastegate size (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">big turbo + low boost = large wastegate.. more exhaust gases to vent off.. (open more)</TD></TR></TABLE>
The bigger the turbo, the more exhaust is required to spin the turbo, so actually less exhaust that needs to be vented.
how do i know what size my turbo is. i ordered the gt3071r with .82 ar but the only markings on the turbo are on the turbine side and say m33 a/r .60
but my serial number plaque has 700382-5012
so maybe that 82 stands for the .82 a/r ?
just wanna make sure i got what i ordered
Re: (B18C1CYA)
i was thinking of that or the hks. hks is pretty $$ tho..
people been telling me the ssac hks style work good too and i dont know if i should cheap out when i have such an expensive setup, but if it works, it works why spend more for nothin.
Re: gt30r b16 wastegate size (voltronR34)
So you have a T2 turbine that looks like this right? http://store.yahoo.com/cheaptu....html
If your turbine looks like that you have an internal wastegate. You don't have to use it, you can weld the flapper shut.
Personally I would go with this wastegate: http://www.jgstools.com/turbo/jgs40wg.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by voltronR34 »</TD></TR><TR><TD CLASS="quote">So you have a T2 turbine that looks like this right? </TD></TR></TABLE>
Re: gt30r b16 wastegate size (B18C1CYA)
also does it matter what water line is the in and out? cause they look like the same threads?
Re: gt30r b16 wastegate size (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">Is that a ported S cover?</TD></TR></TABLE>
so i think its the E cover
rioninja
05-29-2004 12:09 PM
