gt30 hp
Old Jul 11, 2008 | 11:31 AM
maubee_1's Avatar
Default gt30 hp
How much hp is a gt30 good for on a b16a?
Old Jul 11, 2008 | 12:30 PM
B20luda's Avatar
Default Re: gt30 hp (maubee_1)
550whp MAX
Old Jul 11, 2008 | 12:32 PM
welfarepc's Avatar
maybe more...
ive seen one put down 500whp on a SOHC vitara setup
EDIT: it WAS a vitara setup, now weisco, around 27psi
https://honda-tech.com/zerothread/2337047
Modified by welfarepc at 6:02 PM 7/11/2008
Modified by welfarepc at 6:04 PM 7/11/2008
Old Jul 11, 2008 | 01:44 PM
B20luda's Avatar
Default Re: (welfarepc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by welfarepc &raquo;</TD></TR><TR><TD CLASS="quote">maybe more...
ive seen one put down 500whp on a SOHC vitara setup</TD></TR></TABLE>
dosent matter what motor it is, turbo is good to 525whp according to garrett, not gonna get much more out of it than that. I got 520whp out of mine, and it didnt want to hold boost past 20-21psi, could have gotton it to spike some more and maybe taper down to 23-24 and maybe make 550 but i was out of fuel at that paticular time.
Im sure you could push it hard and get mayyyyybe 550whp, that little turbo can only spin so much!!
Old Jul 11, 2008 | 08:11 PM
blinx9900's Avatar
Default Re: (B20luda)
GT30? which one thats pretty damn open, why dont you get your *** over to turbobygarrett.com and find out?
Old Jul 12, 2008 | 04:47 AM
drpoomanchu's Avatar
Your question is pretty vague. I believe you meant to write. How much power is my b16 capable of making w/ the GT30R. You need to post more info on your setup. The turbo is only giong to make what your engine can offer. There are different variants to the GT30. GT3071R, GT3076R, GT37R. You need to give more detailed info on tour setup and power goals if your really looking for good info or second hand opinion.
By the WHP numbers the GT3076R 82AR exhaust housing is good for about 550whp. The 63AR on the other hand is probably good for 525 or so but much better spool on the little B16.
Mine is being tuned right now w/ the 63 ar Ill post the dyno when its finished.
For right now read up
http://www.turbobygarrett.com/...2.htm
Old Jul 12, 2008 | 05:02 AM
DaveF's Avatar
Default Re: gt30 hp (drpoomanchu)
http://www.evans-tuning.com/dy....html
Old Jul 12, 2008 | 07:28 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: gt30 hp (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drpoomanchu &raquo;</TD></TR><TR><TD CLASS="quote">Your question is pretty vague. I believe you meant to write. How much power is my b16 capable of making w/ the GT30R. You need to post more info on your setup. The turbo is only giong to make what your engine can offer. There are different variants to the GT30. GT3071R, GT3076R, GT3040R. You need to give more detailed info on tour setup and power goals if your really looking for good info or second hand opinion.
For right now read up </TD></TR></TABLE>
Like he said, the basic GT3076R (.63A/R) is rated at 525whp. I made the nubers in my sig on a PMTR WITH pistons/rods and the turbo wasn't even breathing hard.
On a stock B16A, it's not how much, but how safe/reliable will it be at that power level.
You, my friend, need to do some reading.
crazybeanery0
Jul 27, 2007 11:23 AM
ek_bape
Jun 9, 2007 04:32 PM
SOHCsleeper
32
Jun 5, 2005 09:50 AM
civicnar
Mar 13, 2005 04:06 PM
JCracer723
11
Mar 24, 2003 01:27 PM
