gt30 with .60 A/R
I would use the larger housing. You can feel the top end taper when using the .63 housings when running over 15 psi on the 3071R and he 3076R. FWIW I tuned an SRT4 with the 3076 and it still managed 402 whp on pump gas although this was at 23 psi. I think the 400 whp mark would have been hit sooner with the larger turbine housing.
The housing is only part of a step process in obtaining the powerband. simply switching housings can help with the process, but its the wheels that make the full change in characteristics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">The housing is only part of a step process in obtaining the powerband. simply switching housings can help with the process, but its the wheels that make the full change in characteristics.</TD></TR></TABLE>
The cheapest way is the housing, you start changing wheels you are talking big bucks.... might as well sell the turbo and get another one.
yusoslo
Apr 27, 2004 07:03 AM
MIKES
Nov 18, 2003 06:40 AM
dyno the car and if the powerband is not to your liking, buy the bigger housing
