GT28RS on Integra LS/VTEC built WILL IT WORK?
Old Jul 11, 2008 | 11:54 AM
typexero's Avatar
Default GT28RS on Integra LS/VTEC built WILL IT WORK?
Hey guys. I have a 1997 Integra LS/VTEC with cp pistons (9:1 compression), Manley rods, B18C1 head with stage 1 cams, exhaust, intake, etc. Anyways, I was wondering if I could use the garret GT28RS turbo with my setup. The reason I question using it is because it is a water-cooled turbo and I don't know how I would go about doing that. I know other cars with water-cooled turbos have their coolant reservoir moved next to the turbo to ensure proper water delivery. Has anyone put a GT28RS in their Integra? If yes do you have to move the coolant reservoir. Thanks.
Old Jul 11, 2008 | 11:56 AM
extralargenog's Avatar
Default Re: GT28RS on Integra LS/VTEC built WILL IT WORK? (typexero)
NO WAI
Old Jul 11, 2008 | 11:57 AM
chimmike's Avatar
yes, you can use it. But for a motor with that kind of work, it'd be, well, underwhelming. I'd go with a bigger turbo if I were you
Old Jul 11, 2008 | 11:58 AM
sp00led's Avatar
Coolant reservoir? All you have to do is run a water line to the turbo and then a return. My source is from where I removed the factory oil cooler and for the return I just tapped my radiator.
Old Jul 11, 2008 | 12:00 PM
chimmike's Avatar
I would recommend against tapping the radiator....there are plenty of other places the return could go.......
Old Jul 11, 2008 | 12:01 PM
typexero's Avatar
Default Re: GT28RS on Integra LS/VTEC built WILL IT WORK? (sp00led)
Would a GT30R provide me with a workable torque curve...will it spool fully before 4500 rpm?
Old Jul 11, 2008 | 12:03 PM
typexero's Avatar
Where in the coolant loop do you recommend putting the turbo?
Old Jul 11, 2008 | 12:05 PM
WalkerGSR1's Avatar
Open down a Gt3076r with .82a/r housing will spool in that 4200-4800 area depending upon where you are and located your setup. I had that same turbo and i made 420 and 325wtq on 16 pounds recirc dump and full 3in exhaust on a 2.0 ls/vtec. I hit full boost 4800-5000 rpm
Old Jul 11, 2008 | 12:06 PM
chimmike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typexero &raquo;</TD></TR><TR><TD CLASS="quote">Where in the coolant loop do you recommend putting the turbo?</TD></TR></TABLE>
I would typcially use the lines that fed the throttle body....of course bypassing the throttle body
Old Jul 11, 2008 | 12:07 PM
chimmike's Avatar
GT30R is an excellent turbo, but for less money you could get a nice bullseye borg warner that will spool just as quick, if not quicker for the power level.
Old Jul 11, 2008 | 12:08 PM
typexero's Avatar
Default Re: GT28RS on Integra LS/VTEC built WILL IT WORK? (chimmike)
Walker where did you put the turbo in your coolant system? Did you experience overheating?
Old Jul 11, 2008 | 12:09 PM
typexero's Avatar
Default Re: (chimmike)
Where could I pick up a bullseye? Can you post a link?
Old Jul 11, 2008 | 12:15 PM
chimmike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typexero &raquo;</TD></TR><TR><TD CLASS="quote">Walker where did you put the turbo in your coolant system? Did you experience overheating?</TD></TR></TABLE>
the turbo is not going to create enough heat in the coolant to overheat the motor.
Old Jul 11, 2008 | 06:10 PM
KENetics1's Avatar
Default Re: (typexero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typexero &raquo;</TD></TR><TR><TD CLASS="quote">Where could I pick up a bullseye? Can you post a link?</TD></TR></TABLE>
contact turbodano
Old Jul 11, 2008 | 06:42 PM
TheShodan's Avatar
Moderator
Or me...
Old Jul 12, 2008 | 12:33 AM
KENetics1's Avatar
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">Or me...</TD></TR></TABLE>
yeah TheShodan too, sorry forgot there's a few more out there too
Old Jul 13, 2008 | 09:54 PM
HiProfile's Avatar
Default Re: (KENetics1)
I'm going to go out on a limb here and assume he's planning on using this car on US streets. Meaning at best, he'll have drag radials on it. Usually people who only drag the car could give 2 dumps about water cooling.
If thats the case, why suggest a turbo that will do 500whp? 350-400whp with a GT28RS or 71r is closer to what he'd want - "a workable torque curve". 450whp with traction problems is usually worse than 350whp w/traction. The best split would be a s256 with a divided housing, or a GT2871R. Both can do 400whp, both will spool fast for the street.
This is the F.I. form, not the DRAG RACING forum, FYI.
Old Jul 14, 2008 | 02:46 PM
Default Re: (HiProfile)
Lets all jump on the new BW bandwagon (looks for rolling eyes emoticon)...
Old Jul 15, 2008 | 07:05 AM
typexero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to go out on a limb here and assume he's planning on using this car on US streets. Meaning at best, he'll have drag radials on it. Usually people who only drag the car could give 2 dumps about water cooling.
This is the F.I. form, not the DRAG RACING forum, FYI.</TD></TR></TABLE>
That's pretty much exactly what TheShodan said when I asked him about it. The GT2871R is my final choice.
Neptune
Jan 8, 2013 10:17 AM
95BoostedEJ1
Feb 22, 2009 08:15 AM
meanEG
Dec 15, 2003 09:44 PM
