GSR vs LS
Old Oct 21, 2004 | 03:07 AM
Eyes Only's Avatar
Default GSR vs LS
Which motor is the best for running boost on the motor a friend of mine and I are debating on either a GSR but I told him a LS would be better because it has the best bottom end. So if I am wrong please correct me.
Old Oct 21, 2004 | 03:22 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: GSR vs LS (Pho Bos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pho Bos &raquo;</TD></TR><TR><TD CLASS="quote">Which motor is the best for running boost on the motor a friend of mine and I are debating on either a GSR but I told him a LS would be better because it has the best bottom end. So if I am wrong please correct me.</TD></TR></TABLE>
If you mean best bottom end because it has weaker rods, a worse RS ratio, no oil squirters and lacks a block girdle then yes it has the better bottom end.
GSR has higher compression so you have to be more precise on the tune, but besides that it will make more power than the LS with the same amount of boost given all things being equal.
It really comes down to how much you want to spend. The LS motor can take plenty of power and can be had for approx $1,500 cheaper or more than your average GSR swap. Due to you having to pump more boost down its throat to make the same power the B18B/LS also makes more torque which can be fun.
&lt; likes his turbo B18B.
Old Oct 21, 2004 | 03:24 AM
Sohc Driver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActiveAero &raquo;</TD></TR><TR><TD CLASS="quote">
&lt; likes his turbo B18B.</TD></TR></TABLE>
What he said
Lovin my b18b ,
Khoi
P.S If financially i could afford both..I would definitely go for the b18c though.
jdmland
Jul 3, 2007 09:29 AM
Boosted_EG8
May 15, 2007 10:48 AM
RevhardLs25
May 3, 2005 08:24 PM
xkhalil333x
Aug 19, 2003 11:39 PM
DIRep972
Jan 17, 2002 03:21 PM
