GSR vs. CTR cams for boost??
Old Jul 29, 2008 | 11:25 AM
Project_EK's Avatar
Default GSR vs. CTR cams for boost??
I'v always thought/heard that CTR cams made more HP/TQ than GSR's?! but i just read a thread where ppl actually said the GSR's are a better cam for turbo and will make for a better power band & more HP??
Modified by Project_EK at 12:37 PM 7/29/2008
Old Jul 29, 2008 | 11:30 AM
rhamlinii's Avatar
Default Re: GSR vs. CTR cams for boost?? (Project_EK)
Every dyno chart i've seen would prove a differn't theory between the two.
Old Jul 29, 2008 | 12:05 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: GSR vs. CTR cams for boost?? (rhamlinii)
type-r cams. simple and very effective for boosted cars. GSR cams are only better than B16cams
CTR cams are pretty agressive. I believe Tye-r's will get what you need
Old Jul 29, 2008 | 12:19 PM
Project_EK's Avatar
Thanks, keep the comments coming...i'm looking to make around 450-500WHP on a 81.5mm 9.1comp GSR w/ls crank & gt3582r
Old Jul 29, 2008 | 12:21 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (Project_EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project_EK &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, keep the comments coming...i'm looking to make around 450-500WHP on a 81.5mm 9.1comp GSR w/ls crank & gt3582r</TD></TR></TABLE>
yeah R cams or skunk 2 cams. R cams are nice though and you can use them on GSR springs and retainers if you keep the revs to 8.5k
Old Jul 29, 2008 | 12:47 PM
Boosted_B_Series's Avatar
ctr/itr cams rock... or skunk2 tuner 1's Mr Evans saw a 30-40hp gain on a high hp setup over the ctr/itr cams with the tuner 1s.. Tuner 1s are easy on the valve terrain, idle like stock, partial throttle drive ability is great and most of the time require no cam gear adj.
Old Jul 29, 2008 | 04:47 PM
boostfeen's Avatar
..Do a search, this topic has been coverd alot. CTR best OEM cam for boost.
Old Jul 29, 2008 | 05:45 PM
blwn95civic's Avatar
Default Re: GSR vs. CTR cams for boost?? (boostfeen)
i was wondering the same question about my car. currently running gsr cams in a ls/v turbo setup. I want a aggressive sound idle but not be impossible to drive on the street. are thte skunk2 stage 2's more aggressive than a R cam?
Not trying to thread jack , i was just about to make a thread about my question so i figured i'd ask since we have similiar questions. Didnt want to clutter the board
Old Jul 29, 2008 | 05:48 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: GSR vs. CTR cams for boost?? (blwn95civic)
get r cams they work great on that set up. When i was fully built that kept 40hp from my set up
Old Jul 29, 2008 | 06:37 PM
xRacerX81's Avatar
i got type r cams in my car, i think they work great on a mild turbo build street car.
Old Jul 30, 2008 | 06:51 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">
yeah R cams or skunk 2 cams. R cams are nice though and you can use them on GSR springs and retainers if you keep the revs to 8.5k</TD></TR></TABLE>
I'm pretty sure you have to keep the revs to 8400, stock revlimit, as to avoid valve float.
Old Jul 30, 2008 | 08:04 AM
Supacharge's Avatar
Default Re: (black_EM1)
either cam will do for the power you want. i run CTRs and made over 660whp on the turbo you are planning on using. it's all good stuff
Old Jul 30, 2008 | 08:30 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">
I'm pretty sure you have to keep the revs to 8400, stock revlimit, as to avoid valve float.</TD></TR></TABLE>
excuse my 100rpm diff
Old Jul 30, 2008 | 10:24 AM
Turbocivic94's Avatar
I run CTR cams in my street car and they make great power. see sig for power
Old Jul 30, 2008 | 10:37 AM
tony413's Avatar
dyno what you have now if you dont like it move up to the CTR/ITR and get cam gears
EvanM1
18
Jun 9, 2010 09:41 PM
revikan
Jul 23, 2008 11:49 AM
Hatchorama
Oct 31, 2005 05:00 AM
Blk95GSR
Sep 18, 2003 01:33 PM
yanasaki
Aug 5, 2003 11:31 PM
