GSR Turbo Problems...
Old Sep 19, 2010 | 06:05 PM
chris3385's Avatar
Default GSR Turbo Problems...
I have a JDM b18c with a sls turbo kit on it with a p28 with hondata s300. I just got another p28 ecu from Phearable and this one came with a paper that says a p28 do not have the option to control the iabs and to block off the vacuum.
Anyhow I had my car tuned about 3 months ago with the vacuum line hooked up which would have kept the iabs closed to my understanding. We put down 276whp at 7psi and ended up cracking the ringlands on #4 piston. I was just wondering if the iabs being closed is what may have caused it to lean out in the upper rpms? They were stock pistons also...
Old Sep 19, 2010 | 09:22 PM
TheShodan's Avatar
Moderator
Default Re: GSR Turbo Problems...
I doubt that. there could be a million reasons of what happened, but that is not a cause
Old Sep 19, 2010 | 09:34 PM
boostedeg302's Avatar
^ Yes, as TheShodan stated, the IAB's being closed did not cause this. Sounds like there was excessive detonation from a few different things. How competent and experienced is the tuner? Start there and correct as you go
lilshady6796
Nov 30, 2009 07:23 PM
blakacintegra
Oct 25, 2006 12:13 AM
GSE980
Oct 11, 2006 08:06 AM
VDoP-B18C1
Jul 12, 2004 03:55 PM
TEGPOWER44
Jan 8, 2003 11:31 AM
