GSR Trans Problems
I have a 95 teg and one night it was fine other then the shift fork for second gear
and i got on it in 3rd and 4th gear and i put in 5th and when i started to slow down it was hard to get it out of 5th gear. After all of that i got it out of 5th and i only had 3rd and 4th i couldnt get it into 1st or 2nd the shifter wouldnt go over that far. Then i went to go to 5th and i bearlly got it into 5th. Then i couldnt get it out of 5th for nothing. I looked underneth with my car on a lift and nothing was hits the linkege or stuck in there underneth.
There was no noise just other then the hard shifting. I did have the input shaft and some other bearing replaced about 10,000 miles ago.
I was planning taking it all apart for the LSD and i was just wondering if anyone else had this problem with a trans at all?
and i got on it in 3rd and 4th gear and i put in 5th and when i started to slow down it was hard to get it out of 5th gear. After all of that i got it out of 5th and i only had 3rd and 4th i couldnt get it into 1st or 2nd the shifter wouldnt go over that far. Then i went to go to 5th and i bearlly got it into 5th. Then i couldnt get it out of 5th for nothing. I looked underneth with my car on a lift and nothing was hits the linkege or stuck in there underneth.There was no noise just other then the hard shifting. I did have the input shaft and some other bearing replaced about 10,000 miles ago.
Try shifting with your car turned off. See if it's any easier, if it goes in the gears easily, but won't go into the gears easily with the car running then your pilot bushing may be bad. I blew mine up, pain in the *** to drive but shifted fine when the car was off.
oldskool teggy
Transmission & Drivetrain
Dec 13, 2015 07:11 PM
