GSR Oilers
GSR Oilers
I've heard around that the oilers in the GSR blocks are just for cooling the stock rods and pistons. But after forged go in, they're not needed anything as the crank and rods oil the cylinder walls. I'm building a boosted car and was wondering what the advantages and disadvantages to taking these out vs leaving them in would be. let me know.
Re: GSR Oilers (BLKTeg94)
the reason they say u don't need them is cause the forged piston cool easier than stock , and blocking them off will bump up your oil pressure, when my buddie built his motor he chose to leave them in , he actually went to honda and bought new ones..he figured honda put them there for a reason plus it wouldn't hurt to have the extra cooling even on forged pistons... go to golden eagle's website they sell the kits to block them off , there is probably info there that may help
So what would be the correct way of cutting them off? Just tappin the holes and put a screw in or do you have to shut off both sides?
Re: GSR Oilers (ReDHaTcHyGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReDHaTcHyGuy »</TD></TR><TR><TD CLASS="quote">go to golden eagle's website they sell the kits to block them off , there is probably info there that may help </TD></TR></TABLE>
i ♥ my honda
Global Mod
Global Mod
Re: (BLKTeg94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKTeg94 »</TD></TR><TR><TD CLASS="quote">So what would be the correct way of cutting them off? Just tappin the holes and put a screw in or do you have to shut off both sides?</TD></TR></TABLE>
Your not going to cut anything. Just tap and plug
Re: (BLKTeg94)
ive always reused the oil squirters.
think about this. s2000 has forged internals from the factory, they still have oil squirters. honda did this for a reason.
476 whp / 323 tq @ 17 PSI
Re: GSR Oilers (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">pros - more oil pressure</TD></TR></TABLE>
i always thought that you dont want too high of an oil pressure for turbo anyways, whats a CON to keeping the oilers? ive always decided to keep them on
Re: (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">ive always reused the oil squirters.
think about this. s2000 has forged internals from the factory, they still have oil squirters. honda did this for a reason. </TD></TR></TABLE>
that says it all right there. i am going to reuse mine
aluminum is one of those metals that gets significantly weaker with increased temp. Also, forged pistons typically have a higher coefficient of thermal expansion, keeping them cooler could mean you could run tighter clearances..although no one actually does.
There is a reason honda built the vtec engines with the oil squirter/oil cooler combo, eliminating it is definitely bad, especially with forced induction.
Re: (rorik)
I don't know why but I always hate these "I'm going to take my oil squirters out" posts.
For street and endurance engines you should leave the arrangement as is. They will do nothing but help your motor regardless of what you have for internals. For highly tuned drag race engines you can find a few horsepower by plugging these orifices. This reduces the oil that falls on the crank, which then robs it of horsepower.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage »</TD></TR><TR><TD CLASS="quote">I kept my oil squirters, I dont care what anyone says, Forged pistons benefit from it too.</TD></TR></TABLE>
Re: (Mase)
think about this. s2000 has forged internals from the factory, they still have oil squirters. honda did this for a reason. </TD></TR></TABLE>Honda S2000 piston to wall clearance is under .001" from the factory and although the S2000 pistons are forged, it is not the same aluminum alloy as an after market piston. If the oem piston expands .001, it is curtains for the block.
Having said all that, you can run the squirters or not. There is no wrong answer to the question.
Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by program »</TD></TR><TR><TD CLASS="quote"> For highly tuned drag race engines you can find a few horsepower by plugging these orifices. This reduces the oil that falls on the crank, which then robs it of horsepower.
Im with this guy, but i dont think you should plug them on a street car
shandonwall
13
04-27-2009 09:13 PM
