GSR head torque values (ARP)
Old Nov 21, 2007 | 09:48 AM
quickspool's Avatar
Default GSR head torque values (ARP)
Just trying to get an idea of what torque values, procedures for the head bolts on a GSR (ARP) thats going to see a fair amount of boost. Curious to see what has worked for others. Thanks.
Old Nov 21, 2007 | 09:57 AM
tony413's Avatar
Default Re: GSR head torque values (quickspool)
unless you brought them used they come with torque values in the box. if not call ARP they can help you with good customer service
but anyways i believe withthe moly lube the torque setting is 75 ft-lbs.
Old Nov 21, 2007 | 10:00 AM
Boner_Ben's Avatar
Default Re: GSR head torque values (tony413)
I usually do about 80 ft-lbs with moly lube using a 3 step torque sequence in the factory order.
Old Nov 21, 2007 | 11:17 AM
quickspool's Avatar
Default Re: GSR head torque values (Boner_Ben)
I have arp's torque values but was wondering what others might have done differently and worked for them. I think I remember some going up to 85 and doing wierd stuff like leaving it sit overnight and then loosing a certain amount and then doing a final torque. Thanks for the replys.
Old Nov 21, 2007 | 11:25 AM
m R g S r's Avatar
you're supposed to go by the valuses ARP provides.......i never did this on mine, butttttttt you are SUPPOSED to torque them, run the engine allow it to heat up and then pull the cams and stuff and re torque them..........too much hassle for my lazy *** and i never had any problems
avotegra
Dec 27, 2015 01:26 PM
PACT man
Sep 7, 2008 10:28 AM
