GSR head on a B16A block?
Old Sep 3, 2004 | 10:12 AM
speedy108's Avatar
Default GSR head on a B16A block?
I had someone give me this block and I would like to use it. I have a '98 GSR head laying around also and just wanted to build another motor. What I need to know is what parts will I have to use for this build as far as timing belt,water pump, oil pump,headstuds,HG,ect......?
Here is the list I came up with and please add on if there is something being left out:
B16 Oil & Water Pumps
B16 Timing Belt
B16 HG (with whatever bore I go with)
B16 Head studs?
Will I have to change cam gears to B16's because of the number of teeth?
Anything else that you can add that I left out, please do.
Thanks.
Old Sep 3, 2004 | 10:58 AM
turbosi03's Avatar
Default Re: GSR head on a B16A block? (speedy108)
so you have built a motor before? I don't understand why your asking these questions if this is true...? or are you just confused about which parts to use because of the GSR head?
are you doing a full build or using stock internals?
if your doing a full build you may want to use aftermarket head studs rather then stock bolts.
dont forget rear main oil seal, cam oil seals, cam oil plug, all your O-rings, intake & exhaust gaskets, oil pan gasket, valve cover gasket, and maybe check out what dowel pins to use for the head, I think they have adaptor dowel pins for b16/LS combo's but not sure about GSR...
good luck!
Old Sep 3, 2004 | 11:08 AM
PrecisionPerformanceParts's Avatar
GSR and B16 cam gears are the same. You just put it together like its a b16. The only differences are the combustion chambers, which don't mean anything on assembly and the intake manifold, which if you buy a gasket kit for a b16, you will need to buy a GSR intake manifold gasket because the b16 won't fit.
Old Sep 3, 2004 | 11:09 AM
speedy108's Avatar
Default Re: GSR head on a B16A block? (turbosi03)
No I'm not doing the build but I am getting all the parts for it. What head studs do I need to use, GSR or B16?
Old Sep 3, 2004 | 01:43 PM
b16 head studs
Old Sep 3, 2004 | 02:06 PM
showtymers619's Avatar
* B A N N E D *
Default Re: GSR head on a B16A block? (PrecisionPerformanceParts)
actaully you should always buy gsr headstuds they fit the b16.. and basicly can be used on ALL b series...buying b16/LS studs is pointless...when you purchase the gsr it can be resold if needed to any1
1320vickers
Engine Machining & Assembly
Aug 3, 2018 12:30 PM
DagoAcura92
Jun 25, 2013 01:44 PM
stellhornata
Mar 16, 2009 04:41 PM
GetawayInMoscow
Feb 27, 2006 12:52 PM
Kimo
11
Dec 16, 2005 04:43 AM
