GSR head on a B16 block
Old Sep 10, 2008 | 02:17 PM
91gsrcivic's Avatar
Default GSR head on a B16 block
I'm building a play toy race car, I have the block and head sitting in my shop along with a turbo set up. Would it be good to assemble all this together? Its all stock, except it needs pistons.
Old Sep 10, 2008 | 02:38 PM
SD_Lurker's Avatar
HT White Ops
Default Re: GSR head on a B16 block (91gsrcivic)
Yeah its fine. Question is rather vague but to answer your question YES a GSR head will make to a b16 block and vice versa.
Old Sep 10, 2008 | 10:23 PM
jarvis199's Avatar
Default Re: GSR head on a B16 block (SD_Lurker)
if u use stock pistons itll pump compression a tad... gsr has smaller combustion chambers...
Old Sep 11, 2008 | 03:04 PM
91gsrcivic's Avatar
Default Re: GSR head on a B16 block (jarvis199)
Well thanks for the imput. I've decided to use the b16 block, crank, and rods(Manley I-beams), with some LS turbo pistons (Wiesco), and stage 2 or 3 turbo cams(Skunk2). Any other suggestions!?
Old Sep 11, 2008 | 06:09 PM
DaveF's Avatar
it would be a wise decsion to put "vtec" pistons in that block. if not, you may have problems with the valve relifs in the piston not being large enough for the "vtec valve's"
Old Sep 14, 2008 | 07:43 AM
91gsrcivic's Avatar
Default Re: GSR head on a B16 block (DaveF)
Yeah, I've been told this by alot of people so I'm going to get some CP low compression turbo pistons. Thanks
Old Sep 14, 2008 | 08:13 AM
TheShodan's Avatar
Moderator
Also, unless you're planning to push over 500whp steady, Skunk2 Pro 1s will work fine. No need for stage 2s or 3s.
Old Sep 16, 2008 | 10:09 AM
91gsrcivic's Avatar
Default Re: GSR head on a B16 block (TheShodan)
Thanks, not real sure as to how much power I'm going to push but I'm going to push it as far as possible with out breaking it. Would like to see it run around the low 10's high 9's.
long beach dc2
Sep 24, 2012 05:38 AM
dc2doi
Aug 4, 2007 10:25 PM
Jesussaves87
10
Jun 26, 2007 06:45 PM
delsollove
Dec 9, 2006 02:32 PM
Nextelbuddy
10
Oct 8, 2003 05:47 PM
