gsr engine size 4 turbo
Old Oct 19, 2003 | 08:40 PM
gsr-2nr's Avatar
Default gsr engine size 4 turbo
tried searcing but didnt find anything to give me a good answer. i would like to turbo my gsr but it be worth it to bore my eng. to 2.0l. and BTW if i go turbo im going ALL OUT i mean full internals 9:0 compression ratio iron sleeved just all out and mayb a t3/t4 60-1 turbo and pushing a minimum of 15psi. or would it be bettr to stay the stok 1.8
Old Oct 20, 2003 | 03:27 PM
gsr-2nr's Avatar
Default Re: gsr engine size 4 turbo (gsr-2nr)
thanks ill do just that
Old Oct 20, 2003 | 04:06 PM
Muckman's Avatar
Moderator in Chief
When I asked the same question most engine builders said is you wont gain as much as you think from the added displacement as you could from just boosting more. And they like to save the extra bore for later down the road when the sleeves are damaged you can bore it out and resleeve. Earl is a good person to talk to about this.
NAgsr
May 20, 2010 04:26 PM
jne
Jun 17, 2009 11:19 PM
slowcrxsib16
Sep 26, 2007 06:00 AM
SOHC_me
Apr 6, 2006 09:12 PM
VTEC-dood
Oct 5, 2004 05:47 PM
