gsr cams in b16a2 head
i was wondering if i switch gsr cams in to my b16a2 head would i have to make any valve adjustments to make up for the increase in lift when using the gsr cams
Re: gsr cams in b16a2 head
Your in the clear. Just be sure you torque all the bolts on the cam caps and rails to spec and in order. You might even replace the cam seal why your at it just to kill 2 birds with 1 stone and prevent future issues.
the guy that is building my engine, he is doing the porting and polishing and valve job said if i were using different cams that i would have to get it adjusted. but i think he thought i was using some radical cams with a large increase in duration and lift, but they are only stock gsr cams
hitvtecgetloud09
31
03-14-2005 09:50 AM
