GSR 14psi AFR???
Old May 25, 2009 | 11:44 AM
BoostnEK6206's Avatar
Default GSR 14psi AFR???
what is a good air to full ratio for 14psi on a 9:1, itr cams, gt3071 turbo? i swear there was a thread awhile back but i cant find it. right now im at 11.2 on 14psi and 11.8 on 9. thats what my tuner has it so i know its good because he knows his ish but just wanna see what others run at
Old May 25, 2009 | 11:52 AM
SilverEk3dr's Avatar
Default Re: GSR 14psi AFR???
as long as you're under 12.5:1 with FI then i would consider that good. If he chose to tune a little rich then that is his discretion. I guess what im saying is if you dont like it find another tuner.
BTW you will not see much of an hp difference by leaning it out. So I would consider it safer to run a little on the rich side.
Old May 25, 2009 | 12:07 PM
Ryank327's Avatar
Originally Posted by BoostnEK6206
what is a good air to full ratio for 14psi on a 9:1, itr cams, gt3071 turbo? i swear there was a thread awhile back but i cant find it. right now im at 11.2 on 14psi and 11.8 on 9. thats what my tuner has it so i figure its good because he knows his ish but just wanna see what others say?
Those are good. Also if you have any reason to not trust your tuner completely then find another. You pay him for a reason, unless you got a free tune than I understand your curiosity
well right i guess what i ment to ask is what other people are running with that psi range. cause i liked how he tuned it. running a little rich is always better cause as stated above it runs 11.5:1.
cause i love my tuner he is a really good guy and knows his ish. just curios to what other poeple run.
Old May 25, 2009 | 02:23 PM
turbodailydan's Avatar
off topic but whats the spec of your engine mate and what exhaust housing are you running? and what power @ 14psi?
afr sounds ideal to me, always better to be safe than sorry..
Old May 25, 2009 | 04:38 PM
LightningTeg's Avatar
Community Builder
Ideal afr is 11.5-12 for boost. You can go leaner on race gas because of the high octane but its all about the tuner.
Old May 25, 2009 | 06:27 PM
stockb18c's Avatar
plus what is your total timing on 14psi
Old Jun 19, 2009 | 04:14 AM
grndcont's Avatar
^ was wondering the same thing.
Old Jun 19, 2009 | 09:14 AM
raene's Avatar
If you're having problems with detonation often your tuner will add a little extra fuel to work as a liquid intercooler.
If you've ever tried to tune a JRSC to redline on a high-comp JDM B18C you'll know what I'm talking about
In other words, 11.5:1 is probably fine. I usually aim for 12:1. I prefer safety over power.
Old Jun 19, 2009 | 01:55 PM
quicksilver1689's Avatar
i ♥ snails
12:1 is safer than 11.5:1?
VegasInvasion
Nov 18, 2008 01:46 PM
99b18
May 21, 2006 04:18 AM
DriveSlowHomie
Sep 23, 2005 05:52 AM
93dx--hatch
Oct 8, 2003 06:04 PM
