greddy turbo timer question please
Old May 4, 2005 | 06:11 PM
ham's Avatar
ham
Default greddy turbo timer question please
92 DX...
Just hooked up a greddy TT I got used. It has no switches or adjustments, just the basics. No manual either
I hooked up the red to white, green to the black w/yellow stripe and the blue to the yellow. The thin black wire to ground. Theres a brown, gray and purple wire I didnt use.
Problem is the TT works and stats counting when I turn the key back, but when I pull the key all the way back to remove, it shuts off with the car.
I've tried other combinations of wiring and it does the same thing any ideas?
Thanks in advance.
Old May 5, 2005 | 03:20 AM
ham's Avatar
ham
Default Re: greddy turbo timer question please (ham)
Old May 5, 2005 | 06:26 AM
igo4bmx's Avatar
im pretty sure brown has to be wired to the ebrake...
Old May 5, 2005 | 09:16 AM
ham's Avatar
ham
Default Re: (igo4bmx)
But what is the ebrake cable? ground or 12v when its pulled up?
Old May 5, 2005 | 09:25 AM
vangc6780's Avatar
Default Re: (ham)
if i can remeber correctly i didnt used the e-brake
Old May 5, 2005 | 09:28 AM
igo4bmx's Avatar
Default Re: (vangc6780)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vangc6780 &raquo;</TD></TR><TR><TD CLASS="quote">if i can remeber correctly i didnt used the e-brake</TD></TR></TABLE>
when ebrake is not activated, it should blink red when counting down also because its warning you about ebrake not being engaged
Old May 5, 2005 | 09:59 AM
ham's Avatar
ham
i thought all you needed to make it work was the 3 wires...
thats all ive used on other TTs
Old May 5, 2005 | 10:07 AM
illusive's Avatar
Ebrake wire is not needed, go to greddys website and double check your wiring. Also there is a cleaner alternitives to splicing. Get a turbo timer harness I know there is a sponsor that sells them on here, makes them plug and play. I have one and it made it so much nicer. I personally hate hacking into harnesses
http://www.greddy.com/tech/FATURBO_TIMER.pdf
Old May 5, 2005 | 04:22 PM
ham's Avatar
ham
fixed!
TKteg
May 18, 2006 05:00 PM
UnKnOwNsLeEpEr
Apr 17, 2006 06:33 AM
trooper0641
15
Jun 26, 2005 05:15 PM
Threads
Jun 7, 2005 04:13 PM
Infinity_Racer
Apr 2, 2003 05:52 PM
