greddy turbo timer question please
92 DX...
Just hooked up a greddy TT I got used. It has no switches or adjustments, just the basics. No manual either https://honda-tech.com/forums/images...es/emdgust.gif I hooked up the red to white, green to the black w/yellow stripe and the blue to the yellow. The thin black wire to ground. Theres a brown, gray and purple wire I didnt use. Problem is the TT works and stats counting when I turn the key back, but when I pull the key all the way back to remove, it shuts off with the car. I've tried other combinations of wiring and it does the same thing https://honda-tech.com/forums/images...s/emsmilep.gif any ideas? Thanks in advance. |
Re: greddy turbo timer question please (ham)
im pretty sure brown has to be wired to the ebrake...
Re: (igo4bmx)
But what is the ebrake cable? ground or 12v when its pulled up?
Re: (ham)
if i can remeber correctly i didnt used the e-brake
Re: (vangc6780)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vangc6780 »</TD></TR><TR><TD CLASS="quote">if i can remeber correctly i didnt used the e-brake</TD></TR></TABLE>
when ebrake is not activated, it should blink red when counting down also because its warning you about ebrake not being engaged |
i thought all you needed to make it work was the 3 wires...
thats all ive used on other TTs |
Ebrake wire is not needed, go to greddys website and double check your wiring. Also there is a cleaner alternitives to splicing. Get a turbo timer harness I know there is a sponsor that sells them on here, makes them plug and play. I have one and it made it so much nicer. I personally hate hacking into harnesses
http://www.greddy.com/tech/FATURBO_TIMER.pdf |
fixed!
