greddy turbo timer problems
Old May 10, 2010 | 03:07 PM
blues-eg's Avatar
Default greddy turbo timer problems
i have it wired in to a plug and play harness but everything i start it it will light up and then say off and shut off, every once in awhile it will turn oon when i push the clutch in. is there some sort of safe mode on it or reset or something i need to fix? i dont have the e brake or speed sensor hooked up
Old May 15, 2010 | 04:56 AM
blues-eg's Avatar
Default Re: greddy turbo timer problems
anyone have any ideas?
Old May 15, 2010 | 06:02 PM
jack81's Avatar
yea man im having issues with a greddy turbo timer i bought used. sometimes it counts down and turns the engine off and other times it just counts down and the engine turns off with the key. i did a search and concluded that the timer is trashed so i ordered a new one off of ebay. i know it's wired correctly as i quadruple checked it and soldered the wires.
Old May 17, 2010 | 08:27 PM
j.liu's Avatar
It's called bad grounding noobs
Old May 18, 2010 | 06:35 AM
jack81's Avatar
my ground is wired into the factory harness, so no bad grounding on my end.
Old May 18, 2010 | 08:40 AM
j.liu's Avatar
are you sure?, I remember the same thing happening to me same functions happen. Then I wired the ground to another bolt where another 2 ground wires were connected too... You might want to double check or wire elsewhere just to see. Goodluckk!
Whiteintegra
Jul 29, 2006 01:13 PM
dohc-crx
Feb 13, 2006 04:07 PM
abmerop18
Jan 13, 2005 04:20 AM
