Greddy turbo question?
Old Jan 30, 2007 | 05:00 PM
kartman5's Avatar
Default Greddy turbo question?
Just installede a greddy turbo on mys sons LS. It's the small one and also has
an intercooler. It came with the greddy FMU and my question is do you believe
that having the car dynoed now to see if it needed a larger fuel pump and injectors would be a good idea before driving it any significant distances. I don't
want ot rebuild another engine.
Also, would it be good idea to replace the FMU with a hondata set-up to bettter tune
it. Some answers with others using this turbo set-up would be appreciated.
Thanks,
Old Jan 30, 2007 | 05:05 PM
da_dude's Avatar
I'll say ditch the fmu and get hondata, uberdata, or crome for EM. Then go dyno tune it. And you'll need bigger injectors too.
Old Jan 30, 2007 | 05:09 PM
kartman5's Avatar
Until a get a better ECU upgrade and dynoed
properly, would you suggest taking it easy
on the engine? Also, can any type of dyno tuning be done with the greddy FMU?
Thanks
Old Jan 30, 2007 | 05:36 PM
BoostedB16EJ's Avatar
Default Re: (kartman5)
depends. if its the "blue box" than no. its all self cointained. if its the emanage unit it is tuneable. the greddy kits come with new fuel injectors. because of the low amount of boost the integra is pulling, the oem fuel pump is sufficient.
Old Jan 30, 2007 | 05:44 PM
kartman5's Avatar
Thanks. I have the boue box, so it looks like
hondata and new injectors. What size do you
think I would need and what would be the
cost. Thanks
Old Jan 30, 2007 | 06:56 PM
the kit should have come with rc 310s. if it didnt thats a good injector if you want to keep it simple. if youre looking to run higher boost ( 10 psi range) get 440s. at that point youll also want a walbro 250 fuel pump
Old Jan 30, 2007 | 11:45 PM
kartman5's Avatar
Thanks for all the help
Old Jan 31, 2007 | 08:14 AM
blaze the chemi's Avatar
The blue box and stock ECU are okay. They also keep your OBD2 car emissions legal.
I would suggest getting a chipped ECU or go with Hondata. 440 cc/min or 550 cc/min injectors would be good.
I am pushing 12-15psi with my greddy kit. I have 550's, but I also have the stock fuel pump. You'd be amazed at what the stock fuel pump is capable of. If you are staying or at 10 psi then you'll be fine with 440's. Good luck.
avotegra
Apr 15, 2007 01:24 AM
my93hatch
Apr 22, 2005 03:45 PM
kcjohnnyboy
Jan 14, 2004 09:27 PM
ProEater
Dec 4, 2003 08:41 AM
n*hance*ek
Dec 7, 2002 11:02 PM
