GReddy Turbo Kit install problem
Ok so my friend and i were putting in my GReddy Turbo Kit on my D16z6 hatch, it was all going good until we hit a little problem. Where the Charge tube hooks up w/ the turbo and where the oil return line hooks up to the turbo are very close together and we cannot fit both of them on. I am confused on what to do, did anyone else encounter this problem? Does anyone have any ideas? thanks in advance.
Re: GReddy Turbo Kit install problem (Yamzz_EG)
mine ended up being a tight fit, not too sure if anyone else experienced the same thing
yeah same here..you can just clock the turbo a bit, but im sure if you play with it, you can manage it to fit
Re: GReddy Turbo Kit install problem (turboD16)
mine wasnt hard at all... try putting the return tap furthest to the passenger side thats what i did
Re: GReddy Turbo Kit install problem (romeo619romeo)
Try hooking up and clamping down the oil return line first, then the charge pipe. It's a small space but it will fit nevertheless.
Re: GReddy Turbo Kit install problem (Trac226)
thanks guys i will let you know how it turns out.
