Greddy Turbo Kit Down Pipe
Old Aug 5, 2002 | 11:17 AM
RedTeg95's Avatar
Default Greddy Turbo Kit Down Pipe
I just ordered a Greddy turbo for my car with all the trimmings and was wondering if anyone with this kit has ever modified the down pipe that comes with the kit or fabricated a new one. The problem is the kit comes with a 2 in. down pipe and I would like a 2.5 in. one in order to fit into my carsound cat. Does anyone already make something like this for the greddy kit? My guess is I will have to make it.
Old Aug 5, 2002 | 01:45 PM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
Default Re: Greddy Turbo Kit Down Pipe (RedTeg95)
Yes! The 2.5" fits best. If I went 3", it will rub one of my charge pipes and the oil pan.
I'll try to post some pix tonight and felt a better pull on the high end!
Old Aug 5, 2002 | 05:34 PM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
Default Re: Greddy Turbo Kit Down Pipe (DB8GSR)
You'll going to get someone to fabricate you a new downpipe if you want to replace the greddy skinnies.
Old Aug 5, 2002 | 06:16 PM
RedTeg95's Avatar
That's kick ***! Did you have someone make that for you or did you do it yourself? I have someone lined up to do it for me. Where did you get the mandrel bent pipe from? Also how did you connect your new pipe without the donut (in other words where does the donut connect or are you using something else as a gasget)?
Thanks
[Modified by RedTeg95, 10:20 PM 8/5/2002]
Old Aug 5, 2002 | 07:52 PM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
Thanks
lol! Oh yah... I had to get it done from this one muffler shop and came out pretty good. The shop that I went actually already had mandrel bent 90 degree pipes so that was easy for me. Bolted right back up and yes, there's a donut that connects between the dp and the test pipe.
Old Aug 6, 2002 | 05:49 AM
RedTeg95's Avatar
Excelent! Thanks for the info.
Old Aug 6, 2002 | 05:57 AM
VTC_CiViC's Avatar
<-- GReddy kit w/ 2.5" DP and flex.
Old Aug 6, 2002 | 07:01 AM
Slater's Avatar
Default Weren't there reports of spiking...
...and creeping with the 2.5 and especially 3" dps on the Greddy kits?
I want to make a 2.5" dp but not if it's going to cause nothing but problems...
Anyone?
- Slater
Old Aug 6, 2002 | 07:08 AM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
Default Re: Weren't there reports of spiking... (Slater)
Anyone?
- Slater
Mine's holding fine @ 7psi with 2.5" dp. The only way you'll get spikes or creeps is when your wastegate starts to go bizerk!
Old Aug 6, 2002 | 07:46 AM
VTC_CiViC's Avatar
Default Re: Weren't there reports of spiking... (DB8GSR)
No problems with my 2.5" DP or straight 3" exahust, wastegate tends to hang on fine untill around 14-15psi.
Old Aug 6, 2002 | 10:40 AM
mod5's Avatar
I want one... The 2.5" downpipe would be great for my set up. I have a '99 GSR w/ Greddy turbo kit and Hondata 2B. Gruvytune will soon be tuning my car.
Anyone selling one that'll bolt onto stock cat? How much would it cost to have it custom fabricated by a muffler shop?
Old Aug 7, 2002 | 08:37 AM
Slater's Avatar
Default Sweet...
...thanks for the info guys.
I know this topic was covered before, but I tried searching and couldn't find it for reference. All I could remember from it was a bunch of people saying that the larger dps caused spikes.
2.5" dp here I come!
- Slater
Old Aug 7, 2002 | 09:56 AM
BoOsTeD_eK's Avatar
Default Re: Sweet... (Slater)
Hey does anyone know where to get those flanges for the end of the downpipe...that looks like the stock one that allows the exhaust to swivel?...in 3"
Old Oct 9, 2002 | 06:04 AM
TORQUE MONSTER's Avatar
are u saying 3' will not work??
Old Oct 9, 2002 | 06:10 AM
DeepSi's Avatar
Default Re: Greddy Turbo Kit Down Pipe (TORQUE MONSTER)
Does anybody replace the second, smaller, part of the downpipe that connects the turbo and the larger part of the downpipe?
Old Oct 9, 2002 | 06:59 AM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
It'll work unless you like putting dents on your oil pan and pinch the oil return line.
The 2.5" dp bolted on as a direct replacement from Greddy's skinny dp by copying the exact measurement and the way the flanges sit. The 3" dp will need to be custom fabricated for it to fit correctly and as a pre-caution, it can be a headache.
[Modified by DB8GSR, 7:59 AM 10/9/2002]
Old Oct 9, 2002 | 07:34 AM
Aeka GSR's Avatar
New User
yes where did you get those flages?
Old Oct 9, 2002 | 10:24 AM
DeepSi's Avatar
so people just replace the larger part of the downpipe and keep the part that connects to the turbo? from the image above that DB8GSR posted that is all that was replaced. Not the smaller 90 degree part that comes off the turbo.
-deepsi
Old Oct 9, 2002 | 11:00 AM
falcongsr's Avatar
What is this crap?
Default Re: Greddy Turbo Kit Down Pipe (DeepSi)
yeah i think you gotta keep the cast part that bolts to the turbine housing. that part is pretty cool i think that was a good idea instead of some of the crazy welded piping i have seen that clears the AC compressor by making a severe angle out of the turbine
Old Oct 9, 2002 | 11:24 AM
DeepSi's Avatar
Default Re: Greddy Turbo Kit Down Pipe (falconGSR)
Well, the 90 degree cast downpipe is small also. so would the 2.5 downpipe really help that much, if the beginning part of the downpipe is a lot smaller. But thinking about it, it would be smiliar to art's downpipe that was 2.5 then flared to 3. so yeah i guess i answered my own question i might just have to look into getting the 2.5 inch downpipe, but then i need a 2.5" cat, and then a larger exhaust, damn, <U>Turbo is priceless</U> .
Old Oct 10, 2002 | 06:07 PM
is that trianglelar flange hard to find or most muffler shops stock them
Old Oct 11, 2002 | 06:55 AM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
Not sure if most regular muffler shops carries them but it's easier to find them on some custom domestic muffler shops.
Old Oct 11, 2002 | 07:44 AM
Andrew 825SM's Avatar
Default Re: Greddy Turbo Kit Down Pipe (VTC_boost-less_CiViC)
&lt;-- GReddy kit w/ 2.5" DP and flex.
Mine Downpipe looks exactly the same as yours, but it goes from greddy downpipe ---&gt; 3 inch downpipe.
Old Oct 11, 2002 | 07:56 AM
LshatchTurbo's Avatar
New User
Default Re: Greddy Turbo Kit Down Pipe (NHB Fighter)
Would you happen to have a pic of your downpipe?
Mine Downpipe looks exactly the same as yours, but it goes from greddy downpipe ---&gt; 3 inch downpipe. [/QUOTE]
Old Oct 11, 2002 | 09:24 AM
Default Re: Greddy Turbo Kit Down Pipe (lshatchturbo)
i posted my downpipe pic awhile back...i'll see if i can find it
