Greddy relief valve
Old Feb 24, 2004 | 07:02 AM
mogz's Avatar
Default Greddy relief valve
Does anyone know what this is and how it works? Does it go on the intake pipe?
Old Feb 24, 2004 | 10:31 AM
mogz's Avatar
Default Re: Greddy relief valve (mogz)
anyone?
Old Feb 24, 2004 | 07:49 PM
Slater's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mogz &raquo;</TD></TR><TR><TD CLASS="quote">anyone?</TD></TR></TABLE>
It's called a pop-off valve, and is used to prevent overboosting. For example, you set it to 15psi and in case your wastegate spikes or a vacuum hose pops off your engine won't boost to infinity and beyond - the vavle will pop off at 15psi (or wherever you set it). It's cheap insurance IMO.
I am running one. I got the Greddy one but you can get the exact same thing from Grainger. I posted the exact a few years ago, but searched and it's long gone.
I will check my hard drive tomorrow b/c I think I may have saved the info. If I find it I will repost the info.
- Slater
BTW, some ghetto old school turbo setups used pop-off valves INSTEAD of wastegates, but it is not as effective as a wastegate and is hard on the turbo.
Old Mar 1, 2004 | 07:11 PM
Slater's Avatar
Default Re: Greddy relief valve (Slater)
Well I looked and couldn't find the original thread, but here's the part from Grainer:
http://www.grainger.com/Graing...item=
$30, and adjustable to whatever pressure you need. I set my Greddy one to 12psi. The Grainer one is 3/4 NPT just like the Greddy one. The range of the Grainger one is 0-20psi. The Greddy one goes to 25psi.
To install it you can either weld a steel 3/4" NPT female fitting from Home Depot to your charge pipe (if your pipes are steel), or you can knock out the brass freeze plug on the side of your intake manifold, tap the opening 3/4" NPT and screw it in there (obviously removing your intake manifold first).
- Slater
umair
Jan 6, 2010 11:37 AM
igo4bmx
Feb 10, 2004 04:50 PM
igo4bmx
Jan 20, 2004 05:29 PM
Cha Shu Bao
Jul 7, 2003 09:58 PM
uneekcrx
May 27, 2002 03:48 PM
