Greddy Large front mount (Type 24)
Old Apr 21, 2002 | 05:15 PM
Cramerox's Avatar
Default Greddy Large front mount (Type 24)
I'de like to ask if anyone is running this intercooler in their integra? any mounting problems? How much cutting did u end up doing?
Old Apr 21, 2002 | 08:43 PM
Cramerox's Avatar
Default Re: Greddy Large front mount (Cramerox)
Anyone?
Old Apr 21, 2002 | 08:55 PM
Flamenco-T's Avatar
you have to cut your bumper support and install a bracket that hang from each side of the intercooler to the bumper support (or what's left os it)
Old Apr 23, 2002 | 04:55 PM
Shaun K's Avatar
I have the Type 24 on my GSR. I just removed the whole bumper support. The IC bolts to the top in the middle with the supplied bracket, and 2 holes in the radiator support where the bumper normally bolts up. The hot pipe on the inlet side bolts to the tow hook.
Old Apr 23, 2002 | 05:13 PM
LsTurbo91's Avatar
Default Re: Greddy Large front mount (Shaun K)
So how do you bolt your bumper back on?
Old Apr 23, 2002 | 07:18 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: Greddy Large front mount (LsTurbo91)
the bumper doesn't bolt to the actual support
Old Apr 23, 2002 | 08:05 PM
Shaun K's Avatar
Default Re: Greddy Large front mount (not so civic)
You just use the top 9-10 bolts and the 2 screws on the sides. I used a couple of self-tapping screws to hold the bottom of the bumper back up so i could get some more ground clearance.
LsTurbo91's Avatar
ok, mine has to be bolted on to the support
Old Apr 23, 2002 | 09:47 PM
Cramerox's Avatar
Sounds good thats what i was looking for....Is there any draw back to taking out the bumper support? will you have trouble remounting the bumper back on?
Got any pics with the bumper on with IC?
Old Apr 23, 2002 | 10:07 PM
Ri5e's Avatar
hmm...no bumper support,... kinda sounds dangerous! I'd rather have a small spearco that mounts underneath the support then have a big *** intercooler that eliminates the bumper support.
Old Apr 23, 2002 | 11:35 PM
SagaGSR's Avatar
Default Re: Greddy Large front mount (BG Boost)
the bumper support is just the 5mph support, if you crash (God forbid) going 50mph, the damage will be nearly the same w/ or w/o that bumper support
maybe thats why the honda decided to change the front ends here, the jdm ones dont have that bumper support, instead its just a small piece of metal about 1" thick
Old Apr 24, 2002 | 06:45 AM
int3gra's Avatar
Default Re: Greddy Large front mount (SagaGSR)
if u look at degradated's crash pics........u will see his intercooler got saved by the bumper support.
is the greddy IC bigger than the revhard?
Old Apr 24, 2002 | 07:24 AM
RCSIVTEC's Avatar
is the type 24 more efficient than the spearco intercooler supplied in the drag kit. what is the deminsions on the spearco intercooler, by the pictures of the type 24 it is bigger than the spearco.
Old Apr 24, 2002 | 08:12 AM
Shaun K's Avatar
Here is a pis on a 99 GSR:
And here's a pic on a 96 GSR:
As for efficiency vs. the Spearco intercooler, I have no idea. I also don't know the Spearco's dimensions. This is the only intercooler I've ever used
[Modified by Shaun K, 9:13 AM 4/24/2002]
Old Apr 24, 2002 | 08:44 AM
Ray's Avatar
Ray
New User
Ditto, guess no skyline intercooler for my car.
reckz
Oct 18, 2011 10:49 AM
pjr710
May 9, 2008 04:18 PM
fastlude69
Jul 14, 2007 08:49 PM
EX-T
Jun 26, 2007 11:13 AM
aaronISthrowed
Sep 19, 2006 08:07 PM
