greddy kit 310cc injectors with AFC hack...will this work
while i'm waiting for my resistor box to come in for my dsm 450cc injectors,
can i use the greddy 310 injectors with the AFC hack for now?
i have a walbro 255 lph high pressure intank pump and SAFC
thanks
Joe
thanks
Joe
From my understanding of the "hack" you should be able to run any injectors that are larger than stock and it should work. Your settings will be different than those with DSM 450, but should work nonetheless. I dont have the "hack", so i am not 100% percent sure.
-deepsi
-deepsi
do not boost because 310s will not supply enough fuel. If you have a FMU with a 8:1 disk laying around, throw that in until the 450s come in. But your intank won't support the fuel pressures so I say just wait.
i got the resistor box!!
ok, so i see 1 harness with 4 black wires and 1 red.
i'm kinda dumb so i'm not sure what to do...
do i just cut the harness off and splice the 4 black wires into the 4 black wires of the injectors? the red one goes to power for all 4??
which wires go to which wire for the black one. does it matter if the 3rd wire on the harness goes to the 1st injector???
i thought this would be easy...just splice inline
turbo95coupe
Dec 2, 2002 12:43 PM
