GREDDY E-MANAGE ECU ENGINE FUEL CONTROL UNIT
Old Jan 5, 2005 | 11:56 AM
MugenFlaredCRX's Avatar
Default GREDDY E-MANAGE ECU ENGINE FUEL CONTROL UNIT
Hey, I have a ZC powered crx and i'm going turbo very soon so I was wondering if anyone knows how well the GREDDY E-MANAGE ECU ENGINE FUEL CONTROL UNIT will work with my setup? if anyone is using this setup also, let me know. thanks
josh
Old Jan 5, 2005 | 12:18 PM
MooreBoost's Avatar
Default Re: GREDDY E-MANAGE ECU ENGINE FUEL CONTROL UNIT (MugenFlaredCRX)
There are tons of threads on the E-manage, search.
In order to make it worth your while you would need to purchase the injector and ignition harness, and if you plan on running over 11 pounds, then you will need their 3 bar sensor also, in which case the entire system is more than Hondata, which will blow the E-manage out of the water.
What are your power goals?
The cheapest route I would take would be an FMU and fuel pump setup. Then you could step up to Turboedit with DSM 450's and a fuel pump, then finally there is Hondata, which you will also need injectors and a fuel pump for.
gstrudler
Engine Management and Tuning
Jul 31, 2018 10:57 PM
aznboi_106
Jul 17, 2010 08:13 PM
MugenFlaredCRX
Jan 5, 2005 11:00 PM
Pfieff
Jul 17, 2003 04:59 AM
zexdrex
Apr 29, 2002 03:08 AM
