Got some head... but WTH is this ??
Old Aug 26, 2002 | 07:47 AM
X2BOARD's Avatar
Default Got some head... but WTH is this ??
Heh heh.... just pulled a B18A head and saw a couple of things and need some info.
I pulled it from the block... not a virgin tho... it had been taken apart once before from the evidence that I had seen. (No time recently tho...)
What I noticed was 2 things...
1) Small amount of rust on ONE of the cam lobes
Should I oil it or get it washed or sanded at a shop ?
2) WTF is this ? It's some type of alignment casting.... don't remember what for, but this small part is broken... is that bad ? Any downsides to it...? Don't seem like much... but that's normally all it takes for a dead motor....
Head Pic #1
Head Pic #2
Notice in pic #2, the Exhaust cam journal #1 has a small broken piece on it...
Any input would be great. I am looking to put this head on an LS block, looking at boost.
X2
[Modified by X2BOARD, 11:49 AM 8/26/2002]
Old Aug 26, 2002 | 07:52 AM
racerxadam's Avatar
Default Re: Got some head... but WTH is this ?? (X2BOARD)
Head Pic #2
[/QUOTE]
that little tab that sticks out is so you can drop a pin through it and the cam when the motor is at tdc. then the cams are locked in place. i don't think it should effect anything.
Old Aug 26, 2002 | 08:00 AM
Speed PHreak's Avatar
Default Re: Got some head... but WTH is this ?? (racerxadam)
Word....but just as long as that little tab isn't bouncing around inside the engine somewhere
Old Aug 26, 2002 | 08:07 AM
X2BOARD's Avatar
Default Re: Got some head... but WTH is this ?? (Speed PHreak)
Coo.... even if the pieces are there, I am dis assembling the head for a possible rebuild.
Thanks for the input !
X2
aimmotorsports
Feb 9, 2008 02:45 PM
89hatcher
Apr 17, 2007 07:58 AM
Al-sonic
11
Dec 19, 2006 03:48 PM
gac_gonejeepin
Jul 23, 2004 03:51 PM
