Got milk? this motor does...
Old Mar 24, 2004 | 06:15 AM
turbosi03's Avatar
Default Got milk? this motor does...
this is my 2.0L b16a2... I'm running a stock motor now that was just tuned, but I would like to figure out what to do with this block. seems that the sleeves moved, I'm curious to know if I can have the deck shaved and get this thing running again dispite everyone telling this block is junk.
yumm looks good!
the head has been cleaned up, inspected, resurfaced and is good...
if your wondering here's whats done to the block:
JG engine dynamics Pro engine II block job (first rebuild)
JG iron sleeves
Comptech engine rebuild : (second rebuild)
resleeved, bored & honed cylinders
resurfaced, balanced and blue printed
polished crank shaft
custom JE forged pistons (9.0:1)
Moly rings and replaced all bearings
Hot tanked
it also has a crower stroker kit to get the 2.0L
the head has some goodies also:
Supertech valves and valve seals (iron valve guides)
Type R rocker assembly
GSR cams
Toda springs and retainers
Multi angle valve job
Port & polish
Old Mar 24, 2004 | 07:21 AM
Finest's Avatar
Default Re: Got milk? this motor does... (turbosi03)
What kind of sleeves are those? I dunno, but it looks like a blockguard that's been welding in? Notice the difference in metal color?
If it's indeed a blockguard, I would check your bore to see if they're truly round. A blockguard can warp the cylinders at the top most portion of the cylinder walls and cause an uneven seal with the HG, hence the mayonnaise.
As for saving the block, you can always resleeve it with more "reputable" sleeves. I cringed when you first said "JG"...
Old Mar 24, 2004 | 07:24 AM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
When a headgaskets paint/finish comes off like that, does that mean they are going bad? I always thought the paint pulled off like that when it was removed...
Old Mar 24, 2004 | 07:25 AM
swatdog's Avatar
wtf is that?
Old Mar 24, 2004 | 07:31 AM
Rtype16's Avatar
Default Re: (swatdog)
Sleeves are okay don't really worry about that it is the installer of the sleeve you have to look out for they didnt seat them properly. You can always have new sleeves put in the block or take it to a reputable shop and have them deck the block and also check to see if the sleeves are seated properly. The milkly mixture is water and oil mixing.
Old Mar 24, 2004 | 07:36 AM
Sohc Driver's Avatar
Default Re: (Rtype16)
wtf causes this?
Wants to know,
Khoi
Old Mar 24, 2004 | 07:40 AM
Default Re: (Sohc Driver)
The mixing of oil and coolant/water causes that.
Old Mar 24, 2004 | 09:26 AM
. o 69 o .'s Avatar
Default Re: (PrecisionH23a)
yup... i blew up my headgasket adn thats exactly what i ended up with. It was also in the rad too..
Old Mar 24, 2004 | 09:51 AM
dfoxengr's Avatar
Default Re: (B16B)
ewww. that block looks like a dumpster motor...
now was it a block guard?
Old Mar 29, 2004 | 06:05 PM
hondawill's Avatar
looks like coolant got mixed with the oil
Old Mar 29, 2004 | 07:26 PM
racinskittle's Avatar
Default Re: (honda_will)
yeah i fixed to headgaskets. That **** is NASTY as ****. Its so gross and it's sooo ******* hard to get off.
GL hope it goes back together and drives good. You better take off the oil pan and clean that up too.
Old Mar 29, 2004 | 07:36 PM
youngkow's Avatar
Default Re: (racinskittle)
How would you get the oil out of the coolan galley?
Old Mar 29, 2004 | 10:30 PM
lazerus's Avatar
Default Re: (youngkow)
buy cheap motor oil and a couple new filters..
put normal oil in it with a new filter.. start it, run for a few minutes. rinse, repeat untill clean
Old Mar 30, 2004 | 07:43 PM
youngkow's Avatar
Default Re: (lazerus)
Thanks, but I meant the coolant galley. Because when I open the radiator, I still have little bits of white chunks come up. And for the oil parts, I was thinking about using sea foam. That should be ok, right? Thanks again.
Old Mar 30, 2004 | 08:31 PM
keebler65's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">Got milk? this motor does...</TD></TR></TABLE>
so does your avatar
thapimpfromchi
Dec 27, 2010 02:23 PM
E85B18
Oct 15, 2009 09:05 AM
ludeboy555
Jan 27, 2004 07:49 PM
philly-O
Sep 14, 2002 06:47 AM
TheSwift1
May 29, 2002 06:56 PM
