Got 35-40 instead of 60 .........will I be ok???
Just honed my sleeved block, I was able to get nice, even, uniformed finish, however, the cross hatch is more like 35-40*. I used a three stone tool with 400 grit. I think the rpm was a little to high because it was moved up and down very swiftly.
Will the rings seat??
Thats good news for me.........all I need to hear now is that there is a slight possibility that a used 2nd comp ring among all new rings may seat with that fresh hone....or at least work for a while with out smoking. Broke one of the new ones.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetlude »</TD></TR><TR><TD CLASS="quote">Just honed my sleeved block, I was able to get nice, even, uniformed finish, however, the cross hatch is more like 35-40*. I used a three stone tool with 400 grit. I think the rpm was a little to high because it was moved up and down very swiftly.
Will the rings seat?? </TD></TR></TABLE>
hold on...... you have a fresh sleeved block, and you just honed it out yourself with what ? a hand drill ? what are you using to measure your bore's ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs »</TD></TR><TR><TD CLASS="quote">the ring i would not skimp on. buy a set of new .. they are cheap.. why put all the work into that and use a used ring. </TD></TR></TABLE>
Well just need to get going for now....... new rings are about 3 week away.
Modified by jetlude at 2:02 AM 1/23/2008
jetlude
Jan 20, 2008 07:00 AM
.:Made in OC:.
Feb 6, 2007 07:59 AM
