good pistons for a boosted b16?
Old Sep 8, 2005 | 12:47 PM
bumsta217's Avatar
Default good pistons for a boosted b16?
hey wassup guys, im runnin a b16a with a t25 turbo @ 10psi and tuned. I decided to move on up to some performance pistons, which do you guys recommend? Also i want to retain stock sleeves. Appreciate your help and feedback guys! Thanks
Old Sep 8, 2005 | 02:45 PM
SpoolnG2's Avatar
Default Re: good pistons for a boosted b16? (bumsta217)
CP...i had nothing but good luck with mine.
Old Sep 8, 2005 | 11:28 PM
bumsta217's Avatar
Default Re: good pistons for a boosted b16? (SpoolnG2)
what kind of CP do u have?
Old Sep 9, 2005 | 01:40 PM
SpoolnG2's Avatar
not sure i understand your question. I was using CP 84mm 9.4:1 pistons.
Old Sep 9, 2005 | 01:43 PM
*Boostwerks*'s Avatar
OEM.
Old Sep 10, 2005 | 11:54 AM
SpoolnG2's Avatar
Default Re: (Bryson)
he's right, oem would be fine. But if you are going to step up and get performance pistons, then you can get an 81.5mm cp piston.
Old Sep 10, 2005 | 12:01 PM
Still_Good's Avatar
Default Re: (SpoolnG2)
SRP, Wiseco, Ross, most all companies have an offering for the B16, and most are competitively priced.
If you aren't going to put a bigger turbo on the car, then you wont need pistons. If you're going to really need the pistons, you're going to need stronger rods too, and probably a bigger intercooler...
Do you get what I'm driving at? The T25 is tiny, and if your goal is to make big power, more than just the pisotns will need attention. That aside,
I've had GREAT luck with my 9:1 wisecos, and I've heard good things about the Ross equivalents. Anything SRP makes is almost gauranteed to cost slightly more, but be of great qaulity.
Old Sep 10, 2005 | 12:57 PM
turboEGhatch's Avatar
Default Re: (Still_Good)
SRP makes budget high silicone pistons and typically are cheaper than Wiseco, Ross, CP, JE, ETC.
Thegreenlude
Jan 17, 2011 01:35 PM
f1 vtec
May 19, 2004 03:41 PM
Sleepin
Jul 16, 2003 06:41 PM
