Good Fuel Setup?
Old Jan 27, 2007 | 08:03 AM
GSROWNSU's Avatar
Default Good Fuel Setup?
Hey guys my plan is to turbo my gsr after i get it all rebuilt this spring. I am starting to slowly accumulate parts for the turbo setup. I just wanted your opinion on my fuel support for the build because this is what i had in mind. (Car will only be running about 7 lbs of boost)
Walbro 255 fuel pump
AEM adjustable fuel pressure regulator with gauge
AEM fuel rail (not needed i know but it's basically free so i'm taking it lol)
RC 550 cc saturated injectors
Let me know what you guys think or if you think i should consider something different.
Thanks,
Dan
Old Jan 27, 2007 | 08:09 AM
Topdawgg's Avatar
that should be fine...
dont really need the fuel rail and fpr but it helps.. I made 320 with stock FPR,rail and it was fine because i had 750s
550s will be fine for under 300whp, but IMO i would upgrade to 750s for any more then that.. Just gives you more room to play with
Old Jan 27, 2007 | 08:13 AM
GSROWNSU's Avatar
Default Re: (Topdawgg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">that should be fine...
550s will be fine for under 300whp, but IMO i would upgrade to 750s for any more then that.. Just gives you more room to play with</TD></TR></TABLE>
Damn 320 on an almost stock fuel setup...nice man! So your sayin i don't even need to increase my fuel pressure with an aftermarket regulator as long as i have a bigger fuel pump and injectors? I didn't know you can do that i figured i needed a fpr to increase the fuel pressure along with the larger injectors.
Old Jan 27, 2007 | 08:20 AM
Topdawgg's Avatar
the FPR will take some strain off the injectors.. but i used a stock fuel setup with a walbro 255 and RC 750s
made decent power and the injectors werent high duty cycle at all
boostfed-wwjd
Apr 23, 2007 06:36 AM
Topdawgg
Nov 24, 2006 05:15 PM
DvD3
Nov 22, 2005 09:55 PM
zeroz
Apr 16, 2005 08:33 PM
