Good EGT range
Old Oct 2, 2004 | 11:09 PM
BoostedJeff's Avatar
Default Good EGT range
Just wondering, what is a safe exhaust temp to tune off of, when under full boost?
Just wondering, cause mine have been lookin kinda high lately.
Old Oct 2, 2004 | 11:38 PM
Default Re: Good EGT range (JDMHatch4Me)
Old Oct 2, 2004 | 11:58 PM
Tchleung's Avatar
ppl are usually around 1,300 to 1,500. Meines for some reason never sees past 1000... porlly cuase I put it in the downpipe but that should effect it that much. oh well.
Old Oct 3, 2004 | 12:30 AM
V-SPEC 1's Avatar
Default Re: (Tchleung)
Mine runs around 1470 deg. fahreinheit, sometimes lower than that.
Old Oct 3, 2004 | 12:31 AM
Agtronic's Avatar
There is a large difference in temps between a probe in the manifold and a probe in the downpipe.
Do you have a wideband? I wouldn't tune off of EGT alone!
Old Oct 3, 2004 | 12:43 AM
Tchleung's Avatar
Default Re: (Agtronic)
Should be here Monday! :D
EDIT: Yeah I jsut did an hour of search. can;t really find any solid answers as to how mcuh difference in temperature change. some say 300 F soem say 500-600F. I made a new thread for it.
Old Oct 3, 2004 | 01:50 AM
Agtronic's Avatar
I have heard that typical variation is around 500°F. I see as high as 1600°F on a long highway boost session with an air/fuel ratio of 12.0:1. That is a little high, but it's 'cause I'm not running enough ignition timing. (Oh, and it's an 8 valve VW motor, so not really anything useful for your purposes, but gives you an idea).
Old Oct 3, 2004 | 06:49 AM
J337_UNIT's Avatar
i get usually like 1400-1450 on the highway in 5th at 3k-3.5k rpm.. it never goes higher then 1450. Usually around town it will be no more then 1200 F
Old Oct 5, 2004 | 09:26 AM
endlesswinterco's Avatar
Default Re: (J337_UNIT)
anyone else, cause im interested as well. someone told me that if you go above 1300 then you are going to burn the pistons up. i have a 12:1 ls vtec all motor, when im on the highway, full throttle, i get up to like 13 and i shut it down cuase im afarid of what i was told. anyone?????
Old Oct 5, 2004 | 10:24 AM
J337_UNIT's Avatar
Default Re: (RidinlowHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RidinlowHatch &raquo;</TD></TR><TR><TD CLASS="quote">anyone else, cause im interested as well. someone told me that if you go above 1300 then you are going to burn the pistons up. i have a 12:1 ls vtec all motor, when im on the highway, full throttle, i get up to like 13 and i shut it down cuase im afarid of what i was told. anyone?????</TD></TR></TABLE>
burning pistons at 1300 degrees F? no. Whoever told u that deserves a . 1450 is normal for cruising speeds. I also know a few people who see 1550 cruising .. ask that dude why they havent burned anything yet? boosting for a while now. no issues
Old Oct 5, 2004 | 08:50 PM
thanks for the insight. what baout at idle, just sitting there, sometimes im at 7 and sometimes im a little below 6
Old Oct 5, 2004 | 09:33 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RidinlowHatch &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the insight. what baout at idle, just sitting there, sometimes im at 7 and sometimes im a little below 6</TD></TR></TABLE>
at idle im around 7-800 F after car warms up fully..
Old Oct 6, 2004 | 07:42 PM
thanks again
Old Oct 6, 2004 | 07:59 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RidinlowHatch &raquo;</TD></TR><TR><TD CLASS="quote">thanks again</TD></TR></TABLE>
no problem
Turbocivic94
Welding / Fabrication
140
Aug 3, 2006 03:57 PM
evoeone
Feb 11, 2003 05:40 PM
gigantor
Aug 28, 2002 03:37 AM
92JDMSiR
Apr 23, 2002 10:31 PM
b18cTurbo
Mar 29, 2002 08:03 PM
