Is this a good build list for a 400hp D series?
Old Mar 25, 2023 | 05:15 AM
ShawnTitus3's Avatar
Default Is this a good build list for a 400hp D series?
I don’t know if this is the correct thread but was just wondering if someone could go over the build list I created and see if it’s good. I have a jdm d15b engine with a d16y8 head and a d16y8 ex transmission.
Here’s the list:
Ycp vitara pistons 75.5mmSkunk 2 alpha connecting rods
Maxpeedingrods gt3582 turbo
Speedfactory street savage camshaft
Skunk 2 pro series adjustable cam gear
Skunk 2 alpha valve spring and retainer kit
Skunk 2 valve stem seal set
Supertech hevn-1012 performance exhaust valves
Supertech hivn-1012 performance intake valves
ACL (5M1932A-STD) Standard Size Main Bearing Set
ACL 4B1956H-STD Rod Bearing Set
ACL 1T1952STD Engine Crankshaft Thrust Washer Set
Skunk 2 alpha 70mm throttle body
Skunk 2 pro intake manifold
Mfactory helical lsd
Huntertuned d series fuel rail
Huntertuned 1000cc injectors
Walbro 255lph hp fuel pump
Aem adjustable fuel pressure regulator
Ktuned fuel pressure gauge liquid filled
Cx intercooler kit for civic
Speedfactory racing heavy duty detent springs
Huntertuned 50mm BOV
Huntertuned 44mm wastegate
ARP head stud kit for d series
Action clutch stage 3 clutch kit for civic
ACR chromoly lightweight flywheel
Cometic Performance Head Gasket C4251-051
Burton racing D series coil plate
Burton racing D series coil on plug kit
NGK d17 coil pack set
NGK Bkr7e spark plugs
SpeedFactory Racing Stainless Steel Ramhorn Turbo Manifold
SpeedFactory Racing 4-Port Boost Control Solenoid Kit
Mishimoto radiator, fan, and coolant piping kit for civic essentials kit
Old Mar 25, 2023 | 08:35 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Is this a good build list for a 400hp D series?
What is the part number for the connecting rods you intend to use ?
Old Mar 25, 2023 | 08:43 PM
The part number for the connecting rods is :306-05-1110
it’s a d16 block rod but I saw on YouTube the guy used the same rods in a d15b and just used a thicker head gasket like the one I have on the list.
Old Mar 26, 2023 | 08:37 AM
NVturbo's Avatar
O.G. triple O.G.
Maxpeedingrods gt3582 turbo ---- NO. You can source a nicer, name brand turbo for a decent price.
Walbro 255lph hp fuel pump --- Go with AEM 340lph. It is E85 compatible.
Aem adjustable fuel pressure regulator --- get an Aeromotive instead
Cx intercooler kit for civic --- opt for a Treadstone and buy the FMIC pipes elsewhere
Burton racing D series coil plate ---- been out of stock FOREVER
NGK d17 coil pack set --- Get Denso instead (p/n# 673-2302). They're much cheaper and works the same.
Mishimoto radiator, fan, and coolant piping kit for civic essentials kit --- ebay no-name aluminum radiator + SPAL 12" fan
Old Mar 26, 2023 | 08:39 AM
awesome thanks for all the help!
Old Mar 26, 2023 | 08:40 AM
Have any turbo suggestions for daily driving 400hp?
Old Mar 26, 2023 | 09:09 AM
NVturbo's Avatar
O.G. triple O.G.
turbonetics t3/t4 turbo and rev 9 38mm gen2 RS wastegate A08007294 A08007296 CB | eBay
That's one helluva deal.
Old Mar 26, 2023 | 09:16 AM
Old Mar 28, 2023 | 07:44 AM
DaX's Avatar
DaX
Loved
Community Favorite
I made 401 whp / 327 ft-lb torque with a Turbonetics TNX C15 52/57 (on E85). It was a great turbo, and I highly recommend it. If that's too expensive, you can look at a knock-off GTX2867R...you'll make good power and have good response with that.
While you can make 400+ on cast Vitara-style pistons, it will eventually limit you if you want to turn it up down the road. Why not spend an extra $500 now and get a standard length rod and some forged pistons?
What fuel will you be running? If E85, you'll be maxing out those injectors and your pump won't be big enough. I recommend 1300cc/min injectors for your goals...assuming E85. Just go ahead and get a Walbro 450 high-pressure and you'll be set with room to grow.
I'd go Aeromotive FPR instead of AEM.
The CX racing intercooler is probably fine, but you're almost surely going to have to modify the piping to fit your car. Go-Autoworks has good, affordable intercoolers and piping kits that actually fit.
3-port solenoid can be less finnicky to tune and get you where you need, but 4-port works too.
Not sure what the Mishimoto fan is like, but I would personally go with the highest flowing Spal fan (wired with a relay) for your radiator that you can fit.
Don't need an adjustable cam gear, aftermarket fuel rail, detent springs, lightweight flywheel, coil-on-plug - save your money and spend it on better pistons/rods, better turbo, machine work, etc.
Are you planning to do sleeves, CSS, epoxy, or anything to reinforce the bottom end?
Don't forget you'll need money for tuning, downpipe, ideally a wideband, gaskets and seals, and other small things that can eat you alive.
Old Mar 28, 2023 | 01:09 PM
thanks for all the help! So I was thinking about doing e85 but in PA where I live we usually only have e87 as the lowest at the pump. Price isn’t really a thing I’m worried about I’m not doing anything to it right now just perfecting the build list and saving up money for it all. Thanks for all the help I really appreciate it and 400hp is max I want on my d15b as I’ll be driving it as my daily so I still want it to be reliable as possible so I’m not worried about room to grow. I’ll still take everything you said into account though thanks again! Have a great day!
Old Mar 29, 2023 | 03:27 AM
DaX's Avatar
DaX
Loved
Community Favorite
don't confuse E85 with the octane ratings at a typical gas pump (87, 89, 91, 93, etc). E85 is 85% ethanol and 15% gasoline (or could be as low as 51% ethanol / 49% gasoline). Most typical pump gas has only 10% ethanol, regardless of the octane rating (87, 89, 91, 93, etc). E85 has something like 104 octane rating. It also usually has a yellow pump handle.
Old Mar 29, 2023 | 05:03 AM
oh gotchu my bad. Where can you usually find it? I don’t think I’ve ever seen e85 in my area and I’ve looked I know that😭 what would be the best fuel system for just e87?
Old Mar 29, 2023 | 06:29 AM
DaX's Avatar
DaX
Loved
Community Favorite
Here's what I use to find stations with E85. Sometimes the map is not up-to-date, though. If you find an error (like a station that no longer carries E85), you can submit it for an update. https://afdc.energy.gov/fuels/ethano...arest?fuel=E85
It's not E87...it's just 87 octane pump gas (drop the E). You do not want to run a turbocharged car on 87 octane. If you're going to use pump gas, use the highest octane rating available in your area...most places have 93, but some places only have up to 91.
If you're limited to pump gas, you'll need to run less timing in your tune, and you'll make less power than you would on E85. BUT...you won't need as much fuel system. 1000 cc/min injectors and a 450 lph pump should be more than enough for your goals on pump gas....if you can get there with your engine. Not sure I've seen a 400 hp D-series on pump gas. You're probably going to need some good head porting to free up any extra ponies you can, since you'll be timing-limited.
You also didn't mention what engine management system you'll be using - what are you planning to use?
Old Mar 29, 2023 | 06:37 AM
Oh gotchu thanks! I’ll be using hondata s300 for the ecu but if there’s a better one that you know about please let me know.
Old Mar 29, 2023 | 06:45 AM
Thinking about doing a flex fuel system now the more I think about it. What would be best fuel injector and pump wise for it?
Old Mar 29, 2023 | 05:38 PM
DaX's Avatar
DaX
Loved
Community Favorite
S300 should be fine. Make sure you replace the capacitors in the ECU if they are original. For your goals I would think 1300 cc injectors and a 400 lph pump would work.
Old Mar 29, 2023 | 05:54 PM
Awesome thanks for the help!
johnls
Feb 6, 2015 02:45 PM
DiMpL3s.
Apr 13, 2010 08:05 PM
civicdx1
Oct 27, 2004 08:53 PM
VtecApprentice
Sep 10, 2002 06:25 PM
