good BRAKES for turbo??
what are some good brakes you turbo ppl use? i wanna be able to keep my stock 15" wheels and brake very fast at the same time..any suggestions on what to do? thanks
Re: good BRAKES for turbo?? (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">I didn't know that braking systems had anything to do with turbos...</TD></TR></TABLE>
I hope your not being scarasitic. if you are
Stock brakes are terrible if you turbo your car.
I'd go with Some brembo blanks and axxis ultimates. The brembo blanks are pretty cheap, about the same price as getting your stock rotors turned.
Id go with wilwood if I had the money. - but you need 17's I beleive.
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: good BRAKES for turbo?? (MachAF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF »</TD></TR><TR><TD CLASS="quote">
No really, I haven't looked into brake upgrades much.
Re: good BRAKES for turbo?? (rota92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 »</TD></TR><TR><TD CLASS="quote">
i thought they make a kit to fit under 15's. or its another company similar to them, SCC used it on there 200 sx road car.</TD></TR></TABLE>
Fastbrakes
http://www.fastbrakes.com
Fastbrakes
Re: good BRAKES for turbo?? (blackANESE)
I agree, http://www.fastbrakes.com the omly company I know of offering a 4 piston caliper setup that will fit with a 15" wheel.
Re: good BRAKES for turbo?? (B18C4-T)
Yah I gotta run 17" rims with my Wilwood setup. If I were running smaller rims I would either go with the Fastbrakes setup or upgraded lines/pads.
Damn wilwoods look soo good though
just some ebc green stuff pads, and bradid lines work good enuf for most. i noticed no diffrence when i went to sloted rotors, they faded at almost the same rate as the non.
Banned
Re: (Stu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stu »</TD></TR><TR><TD CLASS="quote">100mph is 100mph, turbo or not.</TD></TR></TABLE>
yes but with a turbo, you get there so much faster so much more often.
at least i do.
if i was keeping my car, the first thing i would do would be to upgrade the brakes. having them fade at 100+ scared the **** outta me.
at least i do.
Re: (JSMC)
I don't see the reason for upgrading, road race and AutoX guys beat the hell out of their brakes for extended periods of time and have no problems using stock, or near stock, setups. You will not stop sooner with a big brake kit, they will just be more resistant to fade, unless you are pushing the stock system beyond its limits save your money.
Re: (jerseykid609)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerseykid609 »</TD></TR><TR><TD CLASS="quote">stock size rotors and good pads work just fine </TD></TR></TABLE>
I had the same set-up as above and the braking was horrible... I bought a set of brembo blanks up front and front/rear Hawk HP plus race pads and they stop 100x better
Re: (Stu)
yea but with turbo you get there quicker and with much more momentum which takes more force to slow down.
Re: (BoostedH23a1)
Anyone see this on fastbrakes?
http://www.fastbrakes.com/prod...BH03A
Its an 11" setup for civics/CRX that have 9.5" stock brakes, and it uses all OEM parts.
Pretty cheap too.
Pretty cheap too.
