gonna spray on 195k!! what do you think will happen?
as above. i am going to spray a NX 50 shot in my ls motor with 195k on it. i dont care. i have a b16 to put in and i want to go out with a bang. literally.
Re: gonna spray on 195k!! what do you think will happen? (88crx91integra)
higher mileage doesn't always mean that the motor is shot, but i'm sure it has considerable wear. if it was "babied" most of the 195K then it may take the 50 shot like nothing for awhile. just make sure the mixture is correct, if not you can blow a perfectly good motor with improper tuning etc.
see how long it lasts.
if your compression is good and you dont cry right after another id say itll last for a while. Probaly end up lasting longer than you think
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra »</TD></TR><TR><TD CLASS="quote">i have a b16 to put in and i want to go out with a bang. literally.</TD></TR></TABLE>
**** it, make it a 100 shot then just please get it on film
I put a non-intercooled t3 set up boosting 8psi on my integra that had 195,000 on it. It now has 205,000 and it runs as strong as ever. It all depends on if the engine is in good condition to start with.
HELLO,GOOD MORNIN'
Re: gonna spray on 195k!! what do you think will happen? (SPORE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPORE »</TD></TR><TR><TD CLASS="quote">As long as the compression is ok it should take it...If not, you get a cool video </TD></TR></TABLE>
I agree. IF the engine is healthy.....go for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra »</TD></TR><TR><TD CLASS="quote">i dont care. i have a b16 to put in and i want to go out with a bang. literally.</TD></TR></TABLE>
Better make it a 125 shot at least then. You can spray a 50 shot forever and that thing probably wouldn't blow (unless you didn't add any fuel and detonate).
Re: gonna spray on 195k!! what do you think will happen? (RyanCivic2000)
should be ok. just have enough fuel, otherwise you'll see washers flying everwhere
Re: gonna spray on 195k!! what do you think will happen? (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">
**** it, make it a 100 shot then just please get it on film </TD></TR></TABLE>
Agreed, if you are trying to blow it will last way longer than you think just to make you mad. Try at least 100! For some reason everytime someone actually tries to blow a motor they have trouble doing it. Personally the night before I swapped my d16z6 in I took my turbo d15b7 out with the wastegate not hooked up. I spiked over 20 psi on a stock block with an fmu and it did not blow. Got some detontion on the top end then the clutch started slipping near redline. Tried it many more times but the clutch let loose at 10 psi everytime. I think the clutch saved the motor, not enough load to blow it . The sound of the turbo and bov at the level made it worth it though.
Modified by omahaturbocivic at 6:31 PM 6/3/2003
Re: gonna spray on 195k!! what do you think will happen? (falconGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
two words:
holy ****.
two words:
holy ****.
I have seen a LS motor with 150 K on it go through 4 bottles of a 150 shot. GOD DAMN that thing was fast!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: gonna spray on 195k!! what do you think will happen? (jdmhatch138)
I also have seen a older 89 accord take a 125 shot about 10-15 times before the ringlands went.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra »</TD></TR><TR><TD CLASS="quote">gonna spray on 195k!! what do you think will happen?</TD></TR></TABLE>
you will be my hero if u make this video. love the open shot(bottle direct to intake with bouncing rev) idea. make sure you enjoy blowing it up though, you'll only get to do it once....well, whats the setup on the b16, hell you could make a habit of it. j/k ....MAke that video WHOA-DEE
Re: gonna spray on 195k!! what do you think will happen? (RyanAutry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanAutry »</TD></TR><TR><TD CLASS="quote">
