Golden Eagle Block (h23) help please
Does anyone know what size the bore of the sleeves are before "bore and hone"? Cause if the bore is already 87mm I dont wanna waste my money sending in my pistons.
Thanks
Bobby
Thanks
Bobby
sweet well i have 87mm je pistons so then all i will need is to hone it to the pistons? Is this certin that they come with 87mm? Anyone with a h23 Ge block varify this?
you still have to do a hone job but 87mm is std sleeving on the h22/h23 motors. 81mm on the B series motor but a hone is required when installing the pistons
When we sleeve a block, and the customer does not indicate what bore size they will be using, we will then leave the bore about .03" under so your can take it out to stock size. If you ask for a certain bore size like 89 mm, then we leave the bore .03" under so it can be bored to 89 mm easily. So, to answer your question, if you told us stock, or nothing at all, then the block will be returned to you with a .03" under stock size bore!
Vince, i sent in a block about a year ago and said i was gonna use 84mm bore, but i was gonna get the bore and hone done locally. What size bore would it be when u guys sent it out? I figured it is still at 81mm right? Thanks, Paul
[Modified by TurboD16Z6, 10:44 AM 4/3/2003]
well heres the deali bought some used pistons that already have rods on them are you gonna make me take these rods off??? or can you work around them for me? Anyone know about how much UPS charges to deliver this block? Im about to go up there and i wanna make sure i got enough cash.
Shipping from TX will cost about $35 and we can work around the rods. Please include and instruction sheet with the block that details work to be done as well as contact info and payment unless autorized before by a Golden Eagle rep. Thanks.
