GM map sensor + vafc?
Old Jun 22, 2003 | 08:19 PM
RudeLude's Avatar
Default GM map sensor + vafc?
could this setup work for like 15-18 psi max? installed in a h22a built.
daniel
Old Jun 22, 2003 | 10:02 PM
pissedoffsol's Avatar
25 Year Member
Default Re: GM map sensor + vafc? (RudeLude)
i don't know if it will work... but i want to ask WHY?
18 psi requires a lot of fuel, and more so, control of it.
going big is not cheap.
Old Jun 23, 2003 | 12:26 AM
dirtySOHC's's Avatar
Default Re: GM map sensor + vafc? (pissedoffsol)
IMO if you are running anything higher than 10psi you should run hondata or AEM.
Old Jun 23, 2003 | 10:13 PM
RudeLude's Avatar
so does anyone know if this setup will work?
Old Jun 24, 2003 | 01:21 AM
25 Year Member
Default Re: (RudeLude)
even if it can be physically done, you don't want to do this man.
Old Jun 24, 2003 | 01:44 AM
ross1459's Avatar
you gotta have a standalone and mad tuning for that much boost. along with some bulletproof internals
Old Jun 24, 2003 | 01:51 AM
liam821's Avatar
25 Year Member
Default Re: GM map sensor + vafc? (dirtySOHC's)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtySOHC's &raquo;</TD></TR><TR><TD CLASS="quote">IMO if you are running anything higher than 10psi you should run hondata or AEM.</TD></TR></TABLE>
Having things like ignition control and better fuel control is vital for a happy high boosted honda motor.
liam
Old Jun 24, 2003 | 08:51 AM
RudeLude's Avatar
ok, so i'll look into hondata then, what about SDS, anyone heard of use that here?
daniel
vtec.dc2
Feb 12, 2004 04:39 PM
Revi
Jan 9, 2004 02:55 PM
RudeLude
Nov 24, 2003 06:50 AM
Pfieff
Sep 2, 2003 06:20 PM
KoRE
Sep 3, 2002 10:05 PM
