gm map sensor on gsr turbo setup
Im trying to put in a 3bar map sensor for my GSR turbo setup, I know I need an adapter for the throttle body and a map sensor from a grand am v6, now my question is do I need a plug also and how would I go about adding it to the ecu, right now Im running a p28 on crome, but I've been told that I need hondata to do this, Im going to eventually build the block and that is why I would like the larger map sensor setup, shoot me any ideas you might have.
You need to get the map sensor and the pig tail to make the install a lot easier. We sell the kits with the pig tail for $ 75 shipped.
You just need to cut the 3 wires coming from you stock map sensor and splice it into the GM 3 bar pig tail that will be supplied.
Then you can simply plug the stock map sensor on the throttel body and that'll keep it plug.
Stan
Stan
