GM knock sensor with AEM EMS?
Old Nov 12, 2003 | 10:06 PM
Garrett's Avatar
Default GM knock sensor with AEM EMS?
I search on the AEM forum, and don't find the information. Is it possible to use a GM knock sensor on a honda engine (with no OEM knock sensor) with the AEM EMS? If yes, which knock sensor should I use?
Thanks you very for your times and help
Old Nov 12, 2003 | 11:40 PM
Mase's Avatar
Default Re: GM knock sensor with AEM EMS? (Garrett)
im pretty sure the newer vette's use a knock sensor, You should be able to calibrate it for use w/ a honda.
Old Nov 13, 2003 | 01:58 AM
hpfsi's Avatar
You want to look for knock sensors from an engine of similar dimensions and displacement. Why not use a honda sensor?
Old Nov 13, 2003 | 08:03 AM
Garrett's Avatar
Default Re: GM knock sensor with AEM EMS? (hpfsi)
AEM tell that we could use any sensor we want, and the GM sensor are a lot cheaper than honda
Old Nov 13, 2003 | 08:32 AM
mskibbz-T's Avatar
Anyone have any opinions/info on OEM vs GM knock sensors? I have a stigma in my head that Honda OEM would be better quality...
Old Nov 13, 2003 | 09:18 AM
CHEETAH's Avatar
I can ship you a honda KS for $50 ... use the honda is much easier and simpler.
Greg
Old Nov 13, 2003 | 10:17 AM
rtype11's Avatar
GM sensors are tuned to the size of motor they run on, if you need to go with the honda knock sensor for your series of motor. but also remember that a honda knock sensor in a stock setup stops listening at 5000rpm. I wouldnt bother.
gabrielsousa
Dec 16, 2015 06:19 AM
reliant_turbo
Engine Management and Tuning
Nov 15, 2008 06:53 AM
RS2 FAB
Mar 17, 2008 09:58 PM
Leviata-N
Mar 13, 2006 11:36 AM
