gm 3 bar map and throwing code 3
Old Jan 10, 2009 | 08:47 PM
killacam661's Avatar
Default gm 3 bar map and throwing code 3
i just installed a gm 3 bar on my gsr turbo, and now it is flashing MAP.... what the hell?
then i switched back to the stock one and it STILL is flashing code 3(3 quick flashes).
Any input would do great i search and found nothin
Old Jan 11, 2009 | 02:31 AM
grndcont's Avatar
Default Re: gm 3 bar map and throwing code 3
how did you tell the ecu that it was no-longer looking for the stock 2 bar? do you have hondata? chrome? when you put the stock map back on did you reset the ecu?
Old Jan 11, 2009 | 08:44 AM
mtber's Avatar
Check your wiring....
Old Jan 11, 2009 | 08:55 AM
i wired it up like it says to on hondata dot com...
Old Jan 11, 2009 | 10:00 AM
ight i fixed it....
the pigtails wired were coming outta the clip so i had to slide em back in.
Now the car starts and dies.... but its not flashing map...i took out my plugs and they were all black and wet(fouled correct?)...
Old Jan 11, 2009 | 07:19 PM
grndcont's Avatar
sounds like it, do they have any smell to them?
Old Jan 11, 2009 | 08:59 PM
mtber's Avatar
Is your ecu tuned for the 3 bar map sensor ?
Old Jan 11, 2009 | 09:08 PM
tegman23's Avatar
x2? Do you have vacum going to the map sensor?
dglassmyer
May 6, 2012 06:13 AM
zbower7
Jun 21, 2004 08:42 PM
CHEETAH
May 20, 2002 09:04 AM
