Evidence of nitrous
Old Sep 14, 2005 | 12:06 PM
Spectrum24x's Avatar
Default Evidence of nitrous
I was wondering, If buying a used car, is there anything to look for to see if the car had previously been running nitrous?
I'm asking because a friend of mine bought a used 99 prelude, and thinks the previous owner may have ran nitrous, are there things to look for to tell for sure?
We did a tune up on his car, and the old spark plugs were ZEX, which from what i understood are commonly used in a nitrous setup.
Old Sep 14, 2005 | 12:28 PM
PM-Performance's Avatar
Default Re: Evidence of nitrous (Spectrum24x)
other thne holes in the intake and holes in the floorboards to run the lines. Not really.
Old Sep 14, 2005 | 12:30 PM
Ti3d in's Avatar
Default Re: Evidence of nitrous (itr206)
Check if the TPS wires have been tampered with.
mike1114's Avatar
Can't you check the welds around the intake manifold!!!!!! (FnF)
Old Sep 14, 2005 | 02:28 PM
Stewie's Avatar
Default Re: Evidence of nitrous (mike1114)
you should be able to tell. THe bottle had to mounted some where so holes must have been left. Maybe a cut vac line for the fpr, but that can easily be replaced. Check to see if the original fuel line is still intact. I'm sure there's other things.
Old Sep 14, 2005 | 02:45 PM
Default Re: Evidence of nitrous (Stewie)
honestly what does it matter if the car runs good and the motor is in good shape?
Old Sep 14, 2005 | 03:09 PM
ProjectDarkBlack's Avatar
do a leakdown test. If it turns up good then either way it doesn`t matter. Other than holes for the lines, tapping, and blowdown tube it would be hard to tell. You could always ask the previous owner
Old Sep 14, 2005 | 03:11 PM
bnut510's Avatar
nahh theres soo many ways of hooking up nos... looking for holes in the intake mani will be useless if the guy didnt even run a direct port setup... and lookin for holes on the intake arm for single fogger could be uselsss to cuz all they gotta do is swap up the intake... and the solenoids and fuel and all that ****.... they can just get new fuel lines.
onewisepunk
Feb 2, 2004 09:58 PM
2civichatchbs
Jan 12, 2004 09:29 AM
92 CiViC gsR
May 20, 2002 03:25 PM
