gem built engine burning coolant
Old Apr 3, 2005 | 05:06 PM
Prelude91siT's Avatar
Default gem built engine burning coolant
not blaming gem at all at least not right now cause i dont know y its doing this.
ok i had this problem i believe know since i first but the engine in just didnt really notice it. i didnt notice it until i really started driving it cause when i first put the engine in i only drove it for about a 1000 miles and then parked it. since i started driving it again i noticed thats i smell coolant burning. its not leaking a drop. but after driving it i can smell that coolant burning smell. my hg went on my like 2 weeks ago and i started to think maybe i was smell in it cause my hg was going bad in a good way cause it didnt mix with the oil. after replacing hg i started smelling burning coolant again. everytime i drive it i smell. so my question is how can i tell y its burning coolant and is it something that gem did. i have godzilla sleeves, eagle rods and arias flat top pistons. also golden eagle i believe put a channel around coolant passages wich i didnt come stock. it has a new hg and still burning coolant. also this is a jdm b20a i believe the only 3rd gen prelude engine they ever built. also this engine has never seen boost yet
see the channel
do u think that this could cause problems
somebody help me i paid to much money for this block for it to be burning coolant on me
Modified by Prelude91siT at 4:12 PM 4/4/2005
Modified by Prelude91siT at 4:13 PM 4/4/2005
Modified by Prelude91siT at 4:14 PM 4/4/2005
Modified by Prelude91siT at 4:15 PM 4/4/2005
Old Apr 3, 2005 | 05:44 PM
m R g S r's Avatar
Default Re: gem built engine burning coolant (Prelude91siT)
Are you using copperspray on the HG?
Has the head been checked for straightness?
How much are you torquing the headstuds?
What headstuds are you using?
Are you torquing in the correct sequence?
May have sunken a sleeve. . . .
Old Apr 3, 2005 | 06:54 PM
DaveF's Avatar
Default Re: gem built engine burning coolant (m R g S r)
is that an optical illusion or does that piston look JACKED in the bore?
Old Apr 3, 2005 | 07:42 PM
PrettyLude's Avatar
tried a can of block sealer?
Old Apr 3, 2005 | 07:54 PM
Muckman's Avatar
Moderator in Chief
is that piston square in the bore?
Old Apr 4, 2005 | 06:44 AM
yes i have tried copper hg spray,
im using oem new headbolts yes they are turqued down in the right sequence i have the honda shop manual.
what is block sealer?
i dont know what u mean by is the piston square in the bore
does anybody think this channal could cause burning coolant problems
Old Apr 4, 2005 | 06:50 AM
fipracing_com's Avatar
Default Re: (Prelude91siT)
I would use ARP head studs first off. Second, what kind of sleeves are those they dont look like Godzilla Sleeves? Also what head gasket are you using? ANd have you had the Head and block checked for flatness?
Good luck
Old Apr 4, 2005 | 07:17 AM
they are godzilla sleeves. no havent got it check for flatness the block was new and the head only had a few 1000 miles on it. so no i didnt check. also i replace the hg like a week ago and the sleeves still looked the way they r now so i dont think one sunk on me
Old Apr 4, 2005 | 07:37 AM
Muckman's Avatar
Moderator in Chief
Ok now that you added more pictures I can see the first picture made the piston look like it was on an angle in the bore.
Another thing to check is your Intake manifold gasket. Coolant enters the head there and it may be leaking.
Old Apr 4, 2005 | 08:04 AM
how does coolant enter the head fromt he intake manifold gasket?
Old Apr 4, 2005 | 08:17 AM
m R g S r's Avatar
Get the head and block checked for straightness...
Then Get some ARP headstuds, OEM ones should not be used on a built motor....They could have stretched already giving you a false torque reading (doubt it)
Then re-assemble and see what happens.
Old Apr 4, 2005 | 10:17 AM
anybody else. is there a way to see where the coolant is buring or y its burning? before i take anything apart again
Old Apr 4, 2005 | 01:37 PM
Muckman's Avatar
Moderator in Chief
To burn coolant it has to enter the combustion chamber and there are 2 likely cuases. #1 is through head gasket and a far distant 2nd is through the intake manifold gasket. There is a coolant line that runs into the head through the intake manifold flange near the #4 cyl.
Old Apr 5, 2005 | 05:53 AM
well its not burn it in the combustion champer cause i dont see any clouds of white smoke. i can just smell it buring coolant from the engine area
Old Apr 5, 2005 | 06:30 AM
ExVtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude91siT &raquo;</TD></TR><TR><TD CLASS="quote">well its not burn it in the combustion champer cause i dont see any clouds of white smoke. i can just smell it buring coolant from the engine area</TD></TR></TABLE>
For all that means, it could be leaking and burning off something else in the engine bay....check
Old Apr 5, 2005 | 08:13 AM
no it doesnt leak a drop. i can smell it coming from the engine in better terms. its not leaking around it or anything like that. its coming from my engine
Old Apr 5, 2005 | 08:17 AM
m R g S r's Avatar
Okay, so it's not leaking externally,
yet,
not burning through the engine's combustion process...
Then I'd say you don't have a problem.
Old Apr 5, 2005 | 08:28 AM
Default OYRING
then how come everytime i get out my car i can smell it. i dont believe its burning in my combustion chambers cause i dont see no white smoke when im driving. its more like its when u drop coolant on ur manifold im getting that smell like it touching something reall hot and just burning. but i cant spot a leak now where. and its smell like its coming from around the block and head area
Modified by Prelude91siT at 7:44 PM 4/5/2005
Old Apr 5, 2005 | 09:42 AM
Muckman's Avatar
Moderator in Chief
sounds like its leaking from somewhere external that you may not be able to see. it will smell like coolant if its pooling on something hot. just let it idle up up to temp and thouroughly check around the engine bay with a flash light. inpect every coolant line.
Old Apr 5, 2005 | 10:48 AM
i will check out everything again.i just recently replaced the hg. and it was doing this before the hg went on my before and not that i replaced it its doing it again. i will double check everything out and post back
ziptie
Jul 24, 2007 11:48 AM
tallyBanned
Aug 18, 2006 08:50 AM
Evolution-93-Ex
11
Jul 2, 2006 11:31 PM
swlabhot
Mar 5, 2006 11:04 PM
94gsr18kid
Dec 29, 2004 08:12 AM
