gauge question... need help..
Old Nov 14, 2003 | 09:58 PM
  #26
UltimateTSI's Avatar
Default Re: gauge question... need help.. (egturbo)
It is drilled right through but not out the other end.
This is the only way to get an accurate reading of the exhaust temp.
I think some people do weld it, but the other way is that the Greddy EGT comes with 2 bolts that hold the EGT Probe in place. There are other EGT's that come with a clamp instead of bolts.
Old Nov 14, 2003 | 10:05 PM
  #27
Here's a how to on an EGT gauge:
http://www.myzero.com/gauges/egt.html
It's for DSM's, but I'm sure most of it should be the same.
I think on Honda's, the cylinder you tap into is different.
Old Nov 15, 2003 | 12:11 AM
  #28
egturbo's Avatar
Default Re: gauge question... need help.. (UltimateTSI)
thanks for the site.. do u guyz have pics of ur egt setups?? im confused it doesnt say how u block the hole off. shouldnt it leak exhuast?
Old Nov 15, 2003 | 12:48 AM
  #29
Dee's Avatar
Dee
I hope you are only using that AF meter as an idiot light when things go REALLY wrong.
EGT should be your next purchase and if you have an adjustable FPR ditch the AFR meter idiot light and get a fuel pressure gauge.
jdmrsx215
Dec 23, 2006 08:00 AM
BrOkEn_Dc2
Apr 15, 2006 11:09 PM
TylerH
Jan 5, 2006 09:38 PM
96gsrvtec1986
Mar 17, 2005 06:36 AM
Fuster_Cluck
May 15, 2003 07:14 AM
