gauge question... need help..
hey wassup guyz i have a triple gauge pod. and for the last year the third pod has been empty i dunno what to get. i got boost and air/fuel ratio guage. what should i get for the third pod? i dont wanna get oil pressure cuz i heard its a bitch to install. and i dont want to mess with my feed line.. any suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO »</TD></TR><TR><TD CLASS="quote">Definitely EGT</TD></TR></TABLE>
i second that...
i second that...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimateTSI »</TD></TR><TR><TD CLASS="quote">EGT would be the best option</TD></TR></TABLE>
hmm but i already got air/fuel ratio guage. isnt that the same almost? stupid question sorry ... is it hard to install a egt? the probe??
yeah my turbo kit is installed. do i have to take out my dp to install the probe? cuz its gonna be a bitch for me if so..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egturbo »</TD></TR><TR><TD CLASS="quote">
yeah my turbo kit is installed. do i have to take out my dp to install the probe? cuz its gonna be a bitch for me if so..</TD></TR></TABLE>
umm no EGT is exhaust gas temp , totally different than air fuel . you drill into the #3 runner on the manifold and put the probe in there .
oil pressure is also a good guage choice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">
oil pressure is also a good guage choice</TD></TR></TABLE>
damn does this mean that i have to remove everything? like the manifold and everything. cuz when drill into it the metal stuff. hmm sounds like alot of work.. cant just put it on my dp?
damn does this mean that i have to remove everything? like the manifold and everything. cuz when drill into it the metal stuff. hmm sounds like alot of work.. cant just put it on my dp?</TD></TR></TABLE>no it has to be in the manifold because if it goes through the turbo the temp will definetly change, just make it a weekend project and make sure you have enough time to do it right
QUOTE=99integralsturbo]no it has to be in the manifold because if it goes through the turbo the temp will definetly change, just make it a weekend project and make sure you have enough time to do it right [/QUOTE]
Just install the guage on the pod, then take it to a shop to get exhaust manifold tapped or unless you can do it yourself. I took mine to get tapped a few days ago, and it took only like 10 mins. Mostly because they have the right tools.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdsports »</TD></TR><TR><TD CLASS="quote">what gauge brand would u recommend? i current have 3 autometer gauges, i could replace the LIGHT SHOW for the EGT.</TD></TR></TABLE>
?? ur sayin u wanna trade? how much u sellin the egt for??
and how much did it cost to get urs tapped UltimateTSI did u have to remove anything? thanks guyz
and how much did it cost to get urs tapped UltimateTSI did u have to remove anything? thanks guyz</TD></TR></TABLE>
Cost me 30 bucks and didnt have to remove anything. They just drilled the heat shield first, then tapped into the exhaust manifold while the engine was running so that the metal pieces get blown out.
Or I think you could find the tap they use and do it yourself as well.
Or I think you could find the tap they use and do it yourself as well.</TD></TR></TABLE>
hmm isnt that gonna mess up the turbine? since the metal stuff is shootin out the exhuast manifold and to the turbo then dp?? sorry for the questions but thats what it sounds like to me..
hmm isnt that gonna mess up the turbine? since the metal stuff is shootin out the exhuast manifold and to the turbo then dp?? sorry for the questions but thats what it sounds like to me..</TD></TR></TABLE>
It wont mess up the turbine at all. This is the way it's done. The metal stuff doesnt reach the turbo or dp cause the metal flakes shoot straight out of the manifold into the air and not through the turbo or dp.
It wont mess up the turbine at all. This is the way it's done. The metal stuff doesnt reach the turbo or dp cause the metal flakes shoot straight out of the manifold into the air and not through the turbo or dp.</TD></TR></TABLE>
lol.. ohhh ok.. cuz i see alot of manifolds on here for sale that have a hole in it.. drilled right through.. so ur sayin that u only drill half way then weld it?
