gaskets
I assume a gasket is needed to attach my dp to my turbo. where would I get this?
also is there a convenient online source from which I can get a gasket for the manifold to the block?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18-c-rx »</TD></TR><TR><TD CLASS="quote">I assume a gasket is needed to attach my dp to my turbo. where would I get this?
also is there a convenient online source from which I can get a gasket for the manifold to the block?</TD></TR></TABLE>
Manifold to block gasket can be purchased at autozone. It's the same gasket as OEM. I highly recommend a metal gasket (i.e mr. gasket)
Kteller.com Atpturbo.com all sell the gaskets i believe.
Which turbo do you have? The typical 5 bolt t3 flange really doesn't require a gasket, the carbon itself will pretty much seal it.
b18b1hmtlove
Feb 24, 2004 06:18 PM
cokex
May 13, 2003 05:18 PM
