garrett turbo question
Old Dec 13, 2010 | 03:19 PM
dcmatt's Avatar
Default garrett turbo question
Thinkin about picking up a used garret turbo and but the only info on it is on the housing. Its says .60 A/R M24. Trying to figure out what trim it is. I know I can open it up and measure but was wondering if the answer was in the serial number. Its 466159-5004. I googled the housing spes and apparently it was available in a few diff trims from 48 to 60. Any help and info anyone might have is greatly appreciated. (Thanks in advance The Shodan!)
Old Dec 13, 2010 | 06:07 PM
TheShodan's Avatar
Moderator
Default Re: garrett turbo question
That is a T3/T04E 60 "trim" (not to be confused with a super 60), in a T31 4bolt .63A/R. Its a good turbo to about 430-440whp absolute maximum. (Don't ask how many psi it takes to get there, because your motor probably isn't built).
Nice turbo good idea. make sure its in good order.
Old Dec 13, 2010 | 09:06 PM
dcmatt's Avatar
Nope not built YET. Can't wait to check it out tomorrow. How much do rebuild kits usually run? Think it would be a good idea to rebuild it before I use it since its used? Thanks again for the wisdom!
Old Dec 13, 2010 | 10:14 PM
TheShodan's Avatar
Moderator
Not necessarily. Remember, these were designed to run tens of thousands of cycles for a number of years.
If you want to invest in $350 to do so, that's fine, but its best to find out if its necessary first before making that kind of investment in a repair.
Old Dec 13, 2010 | 10:37 PM
dcmatt's Avatar
well was hoping you would say it would be 100 in parts if I did it my self. But yea for 350 I believe ill try to get all the life I can out of it.
devney
Mar 24, 2010 11:04 AM
Jeanious
Oct 11, 2008 05:02 PM
hondahatch741
May 30, 2005 12:36 PM
Project_SOHC_EX
May 5, 2003 01:46 PM
AzN_Flava
Oct 8, 2002 01:07 AM
