Garrett Turbo Question?????????
Old Jun 28, 2007 | 10:40 AM
Spec R_GSR's Avatar
Default Garrett Turbo Question?????????
Im Running a LS/VTEC Turbo setup and my oil pressure is set at 80psi at 6500rpm and i heard that with my T series turbo i shouldnt run that high of a oil pressure and i should install a oil restrictor because at that pressure it tends to damamge the turbo seals...........?
Old Jun 28, 2007 | 10:47 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Garrett Turbo Question????????? (Spec R_GSR)
So whats the question? Do you need a restrictor.... YES
Old Jun 28, 2007 | 12:31 PM
TheShodan's Avatar
Moderator
Your oil pressure reading at the block is not the same at the feed line. Checking the feed line (-3AN) at its oil pressure there is most recommended. Some turbos may require and additional restriction. others may not. depends upon the turbocharger used as well.
tasco
Aug 9, 2015 02:16 PM
SpoolnG2
Mar 8, 2010 09:10 PM
Dominick331
Apr 5, 2006 02:13 PM
CRXDrew
Apr 14, 2005 03:55 PM
Firedrake
Sep 24, 2002 11:18 AM
